post processor failed in tapping cycle
Recently, I have a problem when post tapping cycle using fanuc mill-turn post processor. Can someone here help me to solved this problem?
Many thanks..
ivan.stanojevic
There was a variable (gTappingModal) missing in your postprocessor.
Generally, purpose of this variable is to format G84 and G88 tapping cycles.
Please test the attached post carefully.
Cheers
Ivan Stanojevic
Thank's Ivan!! It's works..
Ivan, I still need some modification, how to remove G97 S1000 P12? This code should be in drilling cycle. Thanks
ivan.stanojevic
I have sent you a PM.
Ivan Stanojevic
Thank you Ivan...
