Recently, I have a problem when post tapping cycle using fanuc mill-turn post processor. Can someone here help me to solved this problem?
Many thanks..
Solved by ivan.stanojevic. Go to Solution.
There was a variable (gTappingModal) missing in your postprocessor.
Generally, purpose of this variable is to format G84 and G88 tapping cycles.
Please test the attached post carefully.
Cheers
Ivan Stanojevic
Ivan, I still need some modification, how to remove G97 S1000 P12? This code should be in drilling cycle. Thanks
