I'm trying to help a friend get a Bridgeport mill with EZTRAK to work with Fusion 360. I've opened two tutorial models (Tutorial1_Complete and CAM Mania_Complete) - the simulation works nicely.
But, when I attempt to post process using the "eztrak conversional.cps - Generic EZ-Trak Conversional" post configuration, no matter what I do, I get a file that is called "xxx.pgm.failed" (where xxx is the file number I gave it). And, within the file, at the end, the last line says (both files from the sample parts attached here):
"!Error: Failed to post data."
Can anyone advise what I need to look at or change? I'm very new to this, but have watched all the intro videos...
If I can demonstrate that these example parts will actually work on this machine, it will be a big win!
Thank you,
Stephen
