Post processer fix
Post processer fix
jeffE9ZUY
Post processer fix
jeffE9ZUY
CNC_Lee
@jeffE9ZUY
What are we looking at here or what is the issue you are looking to solve?
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
jeffE9ZUY
I am starting into using the Swarf cut 5 axis in fusion to trim a fiberglass
part .I have use my machine for 6 + years now with hundreds of 3+ axis
cuts and some 5 axis cuts but used an out source tool path post processor .
I have done the necessary settings in the swarf cut, it completes the tool
path in fusion fine the simulation looks right but when I post process it
and send to the machine it come at the part almost backwards B and C are
pointing in the wrong direction and the table comes out too far if left
running it would crash thru the part and jig . Y appears to be correct place
. this 5x cut using the same PP to do all the other 3+cuts so I am
scratching my head as to why
AdamKunzo
What machine do you have? It sounds like a TCP issue. I can help you get your post processor right for your machine.
Sent you message with more details.
jeffE9ZUY
I have an old Motion master machine I don't think it has the TCP installed
CNC_Lee
@jeffE9ZUY
If your post is not providing the required output, I offer post processor development services and happy to work out a solution for your machine! Message me if I can be of further assistance.
CNC Lee
jeffE9ZUY
Please contact me at jeff@fiberglassunlimited.ca
I have a 5axis CNC router that does
not want to post process the correct tool path something to do with the
piviot lenght and the tool length does not seem to be included in the
process.
