Post for Flow Waterjet does not work
Message 1 of 24
 Using this post https://cam.autodesk.com/posts/post.php?name=flow
When trying to open the resulting .ord file in FlowCut, it gives a "incorrect file format" and won't open.
I played around with the .ord file, and by editing the lineCounter and arcCounter values on the first line, I was able to get the Flow software to open it, but the path itself is not correct.  It seems the arc center coordinates are on the wrong line.
I pathed a circle in Fusion, and this is the file I get from the Flow post:
// This file was created by FlowMaster(R), which is proprietary to Flow International Corporation. 11 4
// Created by Autodesk HSM
    3.7895,    3.0000, 0,    0, 0
    3.7895,    3.0105, 0,   60, 1
    3.9895,    3.0105, 0,   60, 1
    4.0000,    3.0000, 0,   60, 1
    3.0000,    2.0000, 1,   60, 1,    3.0000,    3.0000
    2.0000,    3.0000, 1,   60, 1,    3.0000,    3.0000
    3.0000,    4.0000, 1,   60, 1,    3.0000,    3.0000
    4.0000,    3.0000, 1,   60, 1,    3.0000,    3.0000
    3.9895,    2.9895, 0,   60, 1
    3.7895,    2.9895, 0,   60, 1
    3.7895,    3.0000, 0,   60, 0
Trying to open it in the Flow software gives an "Incorrect file format" warning, and won't open it.
After I edit the first line to this:
// This file was created by FlowMaster(R), which is proprietary to Flow International Corporation. 7 4
It will open in Flow, but the path is incorrect:
If I move the arc center coordinates up a line, it generates the correct path:
It seems like a simple fix , but I don't know post processors or JavaScript well enough to fix it myself.
Can anyone help?
Replies (23)
Message 21 of 24
attachment #4 didn't get posted from my previous post.
Message 22 of 24
kyle.kershaw
One of the guys I recruited to test a new post has reported back with positive results. Here's his reply.
Kyle,
Sorry it took me a minute to get back with you. The last post you reverse engineered did work and I got a piece to cut without issues. Thanks so much for working with me and solving my issue. If I have any more problems ill let you know.
I need a few more "positive results" before I'm ready to put this on the CAM posts page. Anyone out there have a Flow and are interested in testing?  Send me a Private Message and introduce yourself......
Kyle Kershaw
Technical Consultant
Message 23 of 24
ryan.olliges
Kyle,
We run quite a few jobs on our routers using Fusion 360 and are stuck using old flow software for flow cut. If you're still looking for people to test out the post processor I would be happy to help.
Ryan
Message 24 of 24
kyle.kershaw
A note to let people know I've recruited @ryan.olliges and am communicating with him via Private Message in the background. Thanks for your help Ryan!
Kyle Kershaw
