HSM Post Processor Forum
Post for a SCM Record 220 with NUM 1080
62 REPLIES 62
Message 1 of 63
6178 Views, 62 Replies
We are looking to fully integrate Fusion360 into our design process and utilize its CAM fuctionality, wanted to see is anyone has a post processor for a SCM Record 220 with a NUM1080 controller?
Thanks!
62 REPLIES 62
Message 61 of 63
voit20
Might be to late to dig up this old post. But im going to try and run this postprocessor on my IMA 210 that runs NUM 1060. But the header text looks alot different would i just be able to add the header info and i should be up and ready to test?  I attached a .txt of original code from the machine. Thanks in advance!
Message 62 of 63
bob.schultz
in reply to: voit20
From what I see there are other differences in the post processor and your sample code, for example at a tool change.  The post will probably need modification to run on your machine.
Bob Schultz
Sr. Post Processor Developer
Message 63 of 63
Nstep007
Cab I bump this post?  I have the same machine,  I need some sort of design software. I already have Aspire, but do not believe it is compatible with the routech. Any and all help is greatly appreciated
Technology Administrators
