PLS Help me about Feed XY I want to show one line
engineer78QJ94
engineer78QJ94
AdamKunzo
You haven't clearly described your request, but I’ll try to assist anyway.
It seems that you have set a different lead-in/out feedrate and cutting feedrate in the operation. You can define both feedrates with the same value, and then only F1000 will be generated at the start of the contour.
In the image, I don’t quite understand why the first lead-in would be at feedrate F333, but the second lead-in is at F1000.
If my response answers your question, please use Accept Solution button.
engineer78QJ94
@AdamKunzo
Thank you for your reply.  I think  ( Feedrate  F333 / Plugne Feedrate )  and (Feedrate F1000 Cutting feedrate ) . I just want to know if it can display only the first line, is that possible? or   Plugne Feedrate  , Cutting feedrate  must be same all the time?
AdamKunzo
Obviously, the feedrates change throughout the programmed toolpath. This typically happens in 2D contour operation when machining multiple contours or when machining is done with multiple Z steps/ side steps.
In such a case, the feedrate changes because the values are different.
