HSM Post Processor Forum
Optional Z Surface probe with only one touch?
3 REPLIES 3
programming2C78B
179 Views, 3 Replies
programming2C78B
I am probing 102 different points along a part, all on the "same" Z. Is there an easy way to probe with only the slow feed touch instead of doing 2, every time? The probe is only 0.05" above the surface after the initial G54 discovery.
Please click "Accept Solution" if what I wrote solved your issue!
3 REPLIES 3
Tomek.G
in reply to: programming2C78B
Tomek.G
Hi @programming2C78B,
I assume you're asking about measuring cycles (probing Geometry).
If so, it is an optional installation for that.
You need to ask for install the new one-touch basic move macro O9726.
Machine should have fast probe trigger detection ability (high-speed skip option enabled).
The existing standard two-touch macro has to be deleted.
Tomek.G
Sr. Technical Consultant
Tomek.G
programming2C78B
in reply to: Tomek.G
programming2C78B
where do you get that from?
Tomek.G
Tomek.G
Inspection Plus Programming Manual
Tomek.G
Tomek.G
