onsrud tech series with b&r controller.
Message 1 of 11
Hi
we are looking at switching to fusion 360 for our c.r onsrud tech series cnc router.
our router has a b&r controller. I have attached the post processor we are currently using in visual mill as an example
thanks
Replies (10)
Message 2 of 11
boopathi.sivakumar
@Anonymous
make sure zip the file before sending.
Could you please zip the file and attach it here
Boopathi Sivakumar
Principal Technology Consultant
Message 3 of 11
have attached zip file
Message 4 of 11
boopathi.sivakumar
@Anonymous
I think you can try with the attached post and if you need any modifications you can post here we can help you to sort out the issue
https://cam.autodesk.com/hsmposts?p=cr_onsrud_fanuc_31i
This is a generic post of onsrud series with fanuc controller, I don't see much difference between the codes, so you can give it a try and let me know the feedback
Boopathi Sivakumar
Message 5 of 11
I tried it but it came up error (cnc fault) before even picking up the tool from the holder.
mabe have to be a modified post processor?
Message 6 of 11
boopathi.sivakumar
@Anonymous
Yes it needs modification. If you have any working nc file which is working fine with the machine then attach the nc file here.i will have look at it.
Make sure zip the file before attaching.
Boopathi Sivakumar
Message 7 of 11
a working nc file from the current software we use or for fusion?
Message 8 of 11
boopathi.sivakumar
Yes working file from the current software which is working fine.
Boopathi Sivakumar
Message 9 of 11
I've attached a job that has quite a few operations. instead of one massive operation we brake them down in case of having to reset of change pieces in the programming.
hope this helps.
Message 10 of 11
any luck with modifying a post processor?
Message 11 of 11
boopathi.sivakumar
@Anonymous
I had checked the sample files you have provided there are lot of changes needs to be incorporated and it needs some back and forth testing of the codes to validate the post. So I suggest you to contact one of our re-sellers to do the job for you.
Autodesk services marketplace
Boopathi Sivakumar
