Hello, new to posting to the forums but have been using this modified Okuma post for a while now. A few things that I was wondering if there was any way to change...
Rigid tapping in the post is automatically set to MM/Min even though the machine reads it as MM/Rev. So exports F1250.0 for a M8x1.25 @ 1000RPM.
Repeat G codes when I use two drilling cycles with G74 the second cycle does not get a G74 placed in the drilling line. Causes drill to rapid instead unless manually put in.
Lastly, any time I want a drill to just feed in and rapid retract it always adds a peck, even though it should have none.
All of this can be worked around but honestly any help would be greatly appreciated. I attached the current post I am using.
