Okuma post processor for OSP-7000M contol
hooverwelding
Message 1 of 10
hooverwelding
Hi all,
 I'm looking for some help with a post processor. Should I be sending my request to [email protected] or posting on this forum?
Carl
Replies (9)
Message 2 of 10
matthew.nichols
For posts we are wanting the idea station to start being used. Here is the link.
https://forums.autodesk.com/t5/hsm-ideas/idb-p/231
Matthew Nichols
Adoption Specialist - MFG
Message 3 of 10
hooverwelding
Thanks! I posted it there. https://forums.autodesk.com/t5/hsm-ideas/idb-p/231
 Carl
Message 4 of 10
matthew.nichols
Awesome!! Thank you Carl!
Matthew Nichols
Message 5 of 10
scottmoyse
Lets start with this. I did this for a HSM Express user for free, then got zero feedback. So... I'm guessing you will be providing feedback 🙂
Scott Moyse
Did your question get successfully answered? Please accept the post as a Solution to help others find it.
CAM Consultant and owner at Nominal Systems. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 6 of 10
scottmoyse
hey @matthew.nichols I'm not sure that the Ideastation is the best spot for control version/model specific post modification requests is it? I think Brad bucked the trend there massively. Otherwise its just for generic base posts, right? Please correct me if I'm wrong.
Scott Moyse
Message 7 of 10
hooverwelding
I'll provide some feedback as soon as I get some time to check it out, may be next week.
Message 8 of 10
hooverwelding
Ok, I did get to use that post some, works great!! The only thing I am changing in the posted code is to remove the line with the comments "(T5 5/16 drill)". I am using NCnet lite for DNC and it has a option to remove comments but it also removes some of the line of code prior to the comment!!
 Thanks, Scottmoyse for the post!
  Carl
Message 9 of 10
scottmoyse
  Carl
Excellent. Good to know. You can turn off some of the comments, apart from the operation comment using some of the options in the post dialog:
Scott Moyse
Message 10 of 10
hooverwelding
Ok, a few things I's like to change in the post processor. ( I'm using "OKUMA-OSP5020M" from Scott Moyse)
I made a small part to post some code
$OPOST.MIN%
N1 G40 G80 G90 G94 G17
N2 G20
N3 G30 P1
(Drill1)     I'd like this removed but an empty line would be great (this is what it posts with "write tools, NO")
N5 M09
N6 T51 M06
N7 S1600 M03
N8 G15 H01
N9 M08
N11 G00 X1. Y1.
N12 G56 Z0.5 H51
N14 Z0.1
N15 G71 Z0.1
N16 G82 X1. Y1. Z-0.6841 R0.05 F4.8 M53
N17 G00 Z0.1
N18 Z0.5
N19 M05
N20 M09
N21 G30 P1     I'd like this changed to G30 P2 to use a different home position that I have set
N24 M02
That's all!!!
   Carl
