HSM Post Processor Forum
Okuma post/probing
3 REPLIES 3
nwichhart
266 Views, 3 Replies
Okuma post/probing
after setting "allowindexingWCSProbing" to true I can get the probe output  I need when using tool orientation on
our 4th axis horizontal m/c
but if I have a Job set up normal to B0. where I don't need to use tool orientation I only get the probe on/off macros and the first protected move macro? does anyone know how to go about fixing this?
Thank you,
Nick
3 REPLIES 3
nwichhart
in reply to: nwichhart
attached is the nc code being posted
Tomek.G
Hi @nwichhart,
Thanks for posting!
I cannot replicate your issue. Could you please share your test part?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Tomek.G
Sr. Technical Consultant
nwichhart
@Tomek.G
It turned out to be my Clearance Height and Retract height.
I had them both set to the same value
