bloodplum,
as per today, the one and only postprocessor that works "well" with HSM/Fusion is the 2013 version cps file, you're surely dealing with ISO files.
Therefore, it is better to handle those file as they're ment to... -> load them with the old "legacy" biesse interface, completely bypassing the infamous BiesseWorks software.
And yes, it is only possible to do that on the embedded windows machine, attached to the cnc model.
Here comes the CIX posts.
Yet other users had noticed that this is somehow between a good and bad idea to deal with CIX outputs. BiesseWorks software is once again involved in the bad processing/handling of highly populated/fragmented CAM operations, spitted out from Autodesk's HSM/Fusion software (to say better: from ANY CAM software)
Final words:
bad luck, no magic solutions here today.
I feel good to say Autodesk has no power to fix this. Biesse should had improved many years ago his software, which is clearly AGED, based on a slow-interpreted meta language AND, most important, unable to handle operations-rich files (even with their native file format)
Hi c3kkos, you'll notice this thread is 3 years old, in which time I have (with help from other users) developed a fully working ISO post for our machines. It wasn't magic, but it sure is nice unlocking the full potential of the machine.
(bloodplum is my old account)
Yes, i understand your position but not your point
This post will only work with aged machines as the new ones already comes with bSolid support. No one gets damaged, only few will be using this.
Since there was no reason to write that reply attaching none to it, i already knew you wouldnt share it to the community.
Yet, u'd be better not share this information without having the will to not posting it.
to say better, this could have been far better as a private message.
No point sayin u got Mars Rocket not allowing any to use. Are you trying to sell it? -_-
Kudos.
I'm starting my quest in modifying the "2013" Generic Biesse post, as its output is not usable for my 2009 Rover CNC.
It's not an easy road to run on, mainly due to lack of documentation.
I'm able to check Biesseworks-generated ISOs, they are useful resources to reverse engineer the code.
Biesse ISO code is full of customizations.
It took me 1 month googling to finally find a deep-forum-thread-buried ancient PDF from Biesse that -at least- explains some of the obscure ISO codes, i will share this doc here, hoping someone joins this new adventure and/or make useful use out of it.
