Need help with fine boring cycle
empiremachine222
empiremachine222
I need to output Q as Xx.x Yx.x in the cycle to retract on an angle. The boring bar is not square to the X axis. The control is a M70 Mitsubishi.
This is what I getting now. TIA.
Inventor Ultimate 2023
Windows 10 Pro
empiremachine222
I have attached a sample file where I retracted on 45 deg. The code only shows movement in one direction as I posted before.
Windows 10 Pro
bob.schultz
Thanks for reporting this, as it is the same in the library Mitsubishi post.  You can output the shift direction in the G76 cycle by replacing the "fine-boring" code in onCyclePoint with the following code.
    case "fine-boring":
      var shift = cycle.shiftOrientation == 0 ? "Q" + xyzFormat.format(cycle.shift) :
        formatWords("I" + xyzFormat.format(Math.cos(cycle.shiftOrientation) * cycle.shift),
          "J" + xyzFormat.format(Math.sin(cycle.shiftOrientation) * cycle.shift));
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(76),
        getCommonCycle(x, y, z, cycle.retract),
        "P" + milliFormat.format(P), // not optional
        shift,
        feedOutput.format(F)
      break;
Bob Schultz
Sr. Post Processor Developer
empiremachine222
I will get to this on Monday. TIA.
Windows 10 Pro
empiremachine222
Works great. Thanks.
Windows 10 Pro
