Need help to program smoothing into G61 / G64
sies5DRVJ
sies5DRVJ
I'm starting to use CAM in Fusion360 and I run a 3-axis milling machine controlled by EdingCNC.
A post processor file was already available for this controller and I've edited it to fit my requirements for as far as I could.
My question is, why do I keep getting G61 (exact mode) in my g-code when I turn on smoothing? I was expecting to get G64 P0.05 when I enable smoothing in my operation with a tolerance value of 0.05, because I see some programming about this in the *.cps file. But unfortunately this is not the case.
Can someone please point me in the right direction for this? I've added the cps file and the resulting g-code for a simple operation is posted below since somehow it won't be added as attachment.
Thanks in advance!
(1001)
(T66 D=6 CR=3 - ZMIN=-12 - ball end mill)
G90 G94
G17
G21
M9
(2D Contour1)
T66 M6
S24000 M3
G54
M8
G0 X34.8 Y0.6
G43 Z15
G61
Z5
G1 Z-11.4 F300
G18 G3 X34.2 Z-12 I-0.6
G1 X33.6 F2500
G17 G3 X33 Y0 J-0.6
G2 X-33 I-33
X33 I33
G3 X33.6 Y-0.6 I0.6
G1 X34.2
G18 G2 X34.8 Z-11.4 K0.6
G0 Z15
G17
M9
M30
@sies5DRVJ try to comment out the lines in the post processor that contain this function?
sies5DRVJ
Thanks for responding. I'm not sure what you mean by "comment out the lines", but if you search for this text, you'll find the section I think is meant to introduce G64 P... commands for smoothing.
(gFormat.format(64), "P"
I guess what I've pasted below are the relevant lines. One level higher is a very big section called "function onSection".
I assume this is supposed to create a G64 code with a P-value if the smoothing tolerance > 0. And else write G61 (exact mode). This is exactly what I want, but don't see happening. Unfortunately I'm not a programmer. I'm just able to recognize pieces of code and experiment from there. Takes me where I want to be in 90% of the cases, but unfortunately, this time, it's not enough...
if (hasParameter("operation-strategy") && (getParameter("operation-strategy") != "drill")) {
    if (properties.smoothingTolerance > 0) {
      if (!g64Active) {
        writeBlock(gFormat.format(64), "P" + xyzFormat.format(properties.smoothingTolerance));
        g64Active = true;
    } else {
      if (g64Active) {
        writeBlock(gFormat.format(61));
        g64Active = false;
I am not a programmer either, i have just a little experience with modifying the Post-processor
so try this, in your place I ll try to add // (comment out) the lines where there r functions you dont need.
      if (!g64Active) {
        // writeBlock(gFormat.format(64), "P" + xyzFormat.format(properties.smoothingTolerance));
    } else {
      if (g64Active) {
        //writeBlock(gFormat.format(61));
