Multi Setup Posts -which function for start of setup?
lindsay.fowler
Message 1 of 23
lindsay.fowler
Hi All 🙂
I am busy building a post processor for my CNC machine.
I based it on a post processor for a generic 3 axis CNC.
All is pretty much as you would expect and quite fun:
I generate opening g-code using onOpen() for the beginning of the file, onClose() to create any customised ending  g-code, I used onToolChange() to write customised code for my tool changes.
Except for this:
Why is there no function for beginning a setup? Something like onBeginSetup() is what I am needing.
Perhaps it is not needed if you are posting out just one setup, but I post multiple setups in one file because I need to flip parts halfway through and the flipped setup has a different coordinate system.
So how can I write code that switches off my spindle and moves it out of the way, so my part can be flipped, at the start of the second setup?
Thanks All 🙂
Accepted solutions (3)
Replies (22)
Message 21 of 23
parobillard
Hi
In Inventor HSM Post:
function onParameter(name, value) {
	if (name == "job-description") {
	//this mean new setup
Message 22 of 23
lindsay.fowler
Thanks. Where is Job Description entered. Or where do you specify the Job Description?
Message 23 of 23
parobillard
It is the name of your "Setup". As I said it work for Inventor HSM, I think it is not the same in other software like hsmwork.
