Mill/Turn Posts for Nakamura or Fanuc
Message 1 of 23
I am looking to post to a dual spindle mill/turn machine (Nakamura AS200L) with Fanuc Control. There is nothing in the post library that fits this requirement. Besides using a similar post and editing myself, is there a 3rd party software that can handle this?
Thanks for helping out.
Replies (22)
Message 2 of 23
bob.schultz
We currently have a Nakamura Mill/Turn post in Beta (follow the provided link to download it).  Please give it a try, visually checking the output and using extreme care when running it on the machine the first time.
Bob Schultz
Sr. Post Processor Developer
Message 3 of 23
Marco.Takx
Hi @Anonymous,
We are at the moment customizing a post for A Nakamura WT100.
HSM post adjustments needed? Find your right contact here.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 4 of 23
Devin.binning
Observer
Observer
Does this post support simultaneous multi axis machining for a nakamura Super NTMX or NTRX 300?
Message 5 of 23
bob.schultz
Hello @Devin.binning,
The Nakamura Mill-Turn Fanuc post does not support a B-axis, so it will not support 5-axis simultaneous machining.
Bob Schultz
Message 6 of 23
richard.stretton
Hi Bob
After nearly 2 years - does this post support 5 axis machining ?
Message 7 of 23
CNC_Lee
@Anonymous @richard.stretton @Devin.binning
You will need a custom post processor written for this machine if none of the generic posts are providing the required output. I offer post processor development services and happy to work out a solution for your machine! Email me at: [email protected] if still needing assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
Message 8 of 23
johnEM9C5
Hi there Sir - did you manage to get your hands on a post for your Nakamura AS200L ? I’m looking for the same mill turn machine , thanks John
Message 9 of 23
thePostmaster
Hi @johnEM9C5
If it has not been done already, I will be able to customise the generic post to generate the correct output for your machine.
Please send me a message if you would like to make use of my services.
Michael
Message 10 of 23
johnEM9C5
Hi Michael, I have downloaded the Nakamura M<ill/Turn Fanuc .cps post processor but it seems to lack some funtions when it comes to controlling the B axis. For example I am trying to move the B axis forward to grab the component but it doesn't seem to advance without error - now this could be partly that I do not understand yet the commands required to move the axis.
It seems you need an M code 1045 to allow the B axis to cross the interference plane if the chuck is closed (M1046 if chuck is open) - there may also be other codes missing. It would require someone who knows that machine to add these requirements in to the post processor .cps file
What do you think? Best wishes John
Message 11 of 23
thePostmaster
Do you have access to any programming documentation for the machine? If we can find the right information I will be able to implement it into the post processor.
I will see what I can find online.
Message 12 of 23
johnEM9C5
Yes I have all the manuals in pdf format and sample programs that execute the sub spindle advance, grab, synchronised turn for parting and retract (program 1073 attached)
Message 13 of 23
thePostmaster
Thanks for these. It looks quite comprehensive. Would you be able to describe when you would need the M1045/6? Would it be prompted by an operation or would it be inserted with a ‘Manual NC’ operation?
Message 14 of 23
johnEM9C5
It’s just before you move the B axis Subspindle to grab the part so example is..
G0G18G40G54G80G97G99T0101(PART OFF TOOL)
G28U0.
M1045(IGNORE CHUCK BARRIER)
G0G54Z-[#503+#505]M51
G28U0
G359
G0G98B#512(RAPID)
I have been noting other missing routines from the standard Nakamura mill/turn post processor - mainly it’s the subdpindle grab routine and I end up inserting some of the lines of code from the example sent in last message
Message 15 of 23
thePostmaster
Apologies for the slow response.
I would like to help you get this sorted.
Please will you email me at [email protected] so we can discuss a rate for the project.
Michael
Message 16 of 23
komlagudu
Community Visitor
Community Visitor
Hi @Marco.Takx
I need PP for Nakamura WT100 for EspritCAM 2020.
Can you help please?
(personal information removed by CGBenner 7/3/2025)
Thanks.
Message 17 of 23
CGBenner
@komlagudu
Hi, and welcome to the forum.  I edited your post to use the @ tag to get @Marco.Takx attention, and also edited your post to remove the email address, as it is never a good idea to share personal information on these open forums.  Good luck!
Chris Benner
Message 18 of 23
Marco.Takx
Hi @komlagudu,
Thanks for reaching out asking for a post processor.
Unfortunately, we don’t build or modify post processors for EspritCAM.
we only Build & modify post processors for Fusion.
My advice is searching for a Esprit reseller in your area who can help you getting a post processor for EspritCAM 2020.
kind regards,
Marco Takx
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Marco Takx
Message 19 of 23
Marco.Takx
Thanks @CGBenner @for tagging me. Otherwise the change was very small that I came across the question!!
have a nice weekend!!!!
Marco Takx
Message 20 of 23
CNC_Lee
@komlagudu
I might be able to assist! Send me a private message and we can further discuss!
CNC Lee
