MECANUMERIC CN7000 POWER AUTOMATION POST PROCESSOR REQUEST
Message 1 of 21
Hello everyone,
I'm new to this forum. I own a cnc machining workshop near Paris, France. I'm using a MECAPRO Mecanumeric portal router equipped with a Power Automation CN7000 controller. Mecanumeric is a leader manufacturer for such machines here in France, there are very common in the signage, plastic/aluminium machining industry and at professional prototype/model maker workshops.
http://www.mecanumeric.fr/produits/1-665/equipements-de-fraisage-3-axes/mecanumeric-machines-cnc-de-...
It would be great if a post processor for these could be added to the Fusion360 PP database. I dont have the skills to program it myself but I would be happy to provide all the necessary information to help develop it and do the testings.
Best
Replies (20)
Message 2 of 21
scottmoyse
Your best bet is to talk to a local reseller, and work with them on it.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 3 of 21
Hi, Moufasa, Ive been searching and asking everybody and everywhere for the post processor in fusion 360 for the exact same machine like yours (MECANUMERIC CN7000) but no luck yet, did you finally get it??? are you able to work with fusion and your machine??? can you help me with the post processor, please....Yury, in Italy, thanks.
Message 4 of 21
Laurens-3DTechDraw
Is this for laser/waterjet cutting? Or is it for milling?
Their website says that some machine are made with drives and control from Siemens.
Have you tried those post processors?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 5 of 21
Hi Laurens,
  This machine is for milling, haven't tried any post processors yet, I'm gonna try the siemens now but if you find any more info on that please, let me know...........thank you so much.
Message 6 of 21
Laurens-3DTechDraw
@Anonymous wrote:
Hi Laurens,
Do you have a programming manual? If so can you upload it so we can see if there are other posts that are close?
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 7 of 21
Laurens, I just got back from my friends shop, we went into the built in computer of the machine to see the software name and it says:
  PA 8000 CNC
  CNC 3.4.7.5E
  HMI V 2-1-5
We even called the offices of MECANUMERIC in Italy but I don't think they'll be much of a help, thanks for your fast response, Yury.
Message 8 of 21
Hi there,
Sorry I didnt saw your message last year about the PA post.
I have not managed to get the post for the machine so far, did you tried the siemens one or found another solution?
If not I should be able to find the post info sheet that came with the machine, if that helps.
Best
Message 9 of 21
AchimN
http://cam.autodesk.com/posts/?p=power_automation
Feedback is very welcome 😉
Achim.N
Principal Technology Consultant
Message 10 of 21
DaRoBu
Hi AchimN,
Thanks for your contribution.
Just tried the PP, it seems some lines are missing in the final code for it to output the files correctly. I dont know if this is particular to my specific machine or if this concerns every PA equipped machine since each vendor probably customizes the software for his own needs.
My machine is a Mecanumeric Mecapro 1015. Attached is a guideline sheet for writing the PP for this machine.
I've also attached a file that works fine on my machine so you can see how it is organized.
Let me know if this helps.
Best regards
David
Message 11 of 21
Hello AchimN,
I m working at MECANUMERIC.
After post-processing, we've some problems.
You can contact me for more informations.
Hakim
Message 12 of 21
DaRoBu
Hi Hakim,
Hope you're doing fine. I tried to use the updated version of the Post but it still doesn't work.
To many manual changes have to be made in the post processed code.
Has your team worked on this since last time?
Best
David
Message 13 of 21
jean-michel_legoff
is is there an update about this topic?
is there a usable post/processor for a CN7000 to drive a Mecanumeric 3 axis CNC?
many thanks
Message 14 of 21
jean-michel_legoff
Is there a validated working version of this Post-Processor for a Power Animation CN 7000 and a Mecanumeric Milling Machine?
Many Thanks
Message 15 of 21
DaRoBu
There is no validated PP that I am aware of. I have made some modifications on the available PA post with good results on a mecapro 1015 but there is still a lot of work to do to get a stable version.
Regards
Message 16 of 21
jean-michel_legoff
Thanks for your answer.
Can you share your version to help us starting from there?
Many Thanks
Message 17 of 21
I have same problem. This PP don't work for CN7000 Power Automation. I used yesterday it.
Help me decide this problem. At attachment I sent description G-code and M-code for CN 7000 Power Automation.
Message 18 of 21
Karlprukk12
Hello! I also work on Mecanumeric mecapro machine with power automation cn7000 controller. I tried the Power Automation post on autodesk website but it still doesnt output correct code. Has anyone got their hands on a working post processor by now? It would be great.
Message 19 of 21
If you are looking for custom post, pm me.
Message 20 of 21
alan.lenormand88LKD
Community Visitor
Community Visitor
hello, do you have any news since the publication of your comment? I am looking for a post processor suitable for fusion 360 for a Meca numérique CNC. If not, do you know of a 3D software that will have it?
Thank you
