MAZAK SEQUENCE NUMBERS
I need help making some changes to my post.  I would only like the sequence number output above each new tool change.  Post attached
Arun.rs
HI @Anonymous
Thanks for raising your concern via Forum .
Open post file in a 'Visual Studio Code' or 'Notepad++' to do the required modifications.
1. Define variable called  ' var sequenceNumberForToolChange; ' , you can define in '// collected state'
2. Search 'function writeBlock' , Add below condition in line number 202
if (properties.showSequenceNumbers || sequenceNumberForToolChange) {
3. Set the state as false for 'sequenceNumberForToolChange' in line number 217
sequenceNumberForToolChange = false;
Modified condition will be as below.
function writeBlock() {
  var text = formatWords(arguments);
  if (!text) {
    return;
    if (skipBlock && text) {
      writeWords2("/", "N" + sequenceNumber, arguments);
    } else {
      writeWords2("N" + sequenceNumber, arguments);
    sequenceNumber += properties.sequenceNumberIncrement;
  } else {
      writeWords("/", arguments);
    } else {
      writeWords(arguments);
  skipBlock = false;
4. Search 'writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6));'  in editor.
5. Write ' sequenceNumberForToolChange = true; ' before toolcall.
Regards
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
Thank you so much for your help works perfectly!!!!   I have another question, on the initial start of the program,  between all tool changes the machine goes to a safe position of:
G53 Z0
G53 X0 Y0 B0 C0
I would like to machine to go home in the only Z-axis and reposition "B & C" where necessary and eliminate the
G53 X0 Y0 B0 C0
I have attached the new version of the post with the "N" number on tool change and G90 added for the "EIA" non-modal restart.
@Arun.rs
Arun.rs
HI @Anonymous
Thanks for the feedback.
If you don't want to output XYBC homing codes for every tool change and in program start, you can just comment it out with "//" in front of it.
// if (insertToolCall) {
    // writeBlock(gFormat.format(53), gMotionModal.format(0), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "B" + xyzFormat.format(0), "C" + xyzFormat.format(0)); // retract
    //   forceABC();
    // } else {
    //   writeRetract(X, Y);
Save the file and test the post carefully.
Regards
Arun.RS
@Arun.rs  this works but the problem is if you transitioning from an operation where C or B was not at 0 deg, nothing forces it back on the next operation to proper B C location.  I have attached a file, for example, after drill, the holes nothings reset B C going to tool 5
