in the last update mazak integrex post, an error crept in. If two or more jobs are in different positions (B axis) with the same tool, the spindle is stopped (M5) and the tool then moves without speed.
Solved by billcainautodesk. Go to Solution.
Hello L_shaver_6167
I am not seeing an M5 come out in that situation. Can you share the project or something similar that shows the M5 coming out?
Nevermind L_shaver_6167, I see the problem now. Will look to fix that.
Hello L_shaver_6167
While I still must test it, looks like we to add something to line 2046
if (insertToolCall ||
newSpindle ||
isFirstSection() ||
isSpindleSpeedDifferent() || newWorkPlane) {
if (machineState.isTurningOperation || machineState.axialCenterDrilling) {
