HSM Post Processor Forum
Mazak 3+2 post processor issue
9 REPLIES 9
Message 1 of 10
wrobel094
1268 Views, 9 Replies
Hello everyone,
I have a problem with G68.2 in my post processor. The code which is generate by G68.2 is different then axis rotation. For example i get something like that:
G0 A-35.132 C90.
G68.2 P1 X0. Y0. Z0. I-90. J35.132 K180.
I achived rotation in A=-90, B=35.132 and C=180 and i do not know how to fix that. Do you guys have an idea?
9 REPLIES 9
Message 2 of 10
andrea.amilo
in reply to: wrobel094
Hi @wrobel094 ,
I think the issue could be related to the order of rotation configured in your postprocessor vs the one expected from your controller.
Maybe you could try to configure your postprocessor to use XYZ static rotation order, written as G68.2P1Q123 in Mazak language.
If so, you can add Q123 argument at line 593 :
writeBlock(gRotationModal.format(68.2), "P1 Q123", "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "Z" + xyzFormat.format(0), "I" + abcFormat.format(abc.x), "J" + abcFormat.format(abc.y), "K" + abcFormat.format(abc.z)); // set frame
and, as a consequence, you could modify EULER order of rotation at line 860 :
var euler = currentSection.workPlane.getEuler2(EULER_XYZ_S);
Please test it carefully and let me know.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
Message 3 of 10
wrobel094
in reply to: andrea.amilo
Thank you for respond Andrea. Now I'm getting something like that:
N40 G0 A-35.132 C90.
N45 G68.2 P1 Q123 X0. Y0. Z0. I180. J35.132 K-90.
After changes u suggested the rotation values are still generated in wrong places.
Message 4 of 10
andrea.amilo
Hi @wrobel094 ,
have you modified also the EULER order of rotation at line 860 ?
Andrea Amilo
Message 5 of 10
wrobel094
Now everything works perfectly. I forgot to change EULER_XYX to EULER_XYZ. Anyway thank you so much Andrea for help!
Message 6 of 10
wrobel094
Hello! I have one more question. Well everything works fine when i have simply axes rotation like:
N45 G0 A-90. C180.
N50 G68.2 P1 Q123 X0. Y0. Z0. I-90. J0. K180.
But when I want to rotate part in more specific way I get this:
N64395 G0 A-5.469 C-164.648
N64400 G68.2 P1 Q123 X0. Y0. Z0. I5.276 J1.44 K0.133
In my opinion code G68.2 generate incorrect values in this case. Can we fix it?
Message 7 of 10
wrobel094
And i have another example when i want to rotate part by 5 degree:
N40 G0 A5. C0.
N45 G68.2 P1 Q123 X0. Y0. Z0. I5. J0.011 K-0.126
Message 8 of 10
wrobel094
Hi again. I think I solved the problem. I make some changes in this section:
writeBlock(gRotationModal.format(68.2), "P1", "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "Z" + xyzFormat.format(0), "I" + abcFormat.format(abc.x), "J" + abcFormat.format(abc.y), "K" + abcFormat.format(abc.z)); // set frame
To this:
writeBlock(gRotationModal.format(68.2), "P1 Q123", "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "Z" + xyzFormat.format(0), "I" + abcFormat.format(angles.x), "J" + abcFormat.format(angles.y), "K" + abcFormat.format(angles.z)); // set frame
Now everytime I get exactly what I want. Will everything be alright if I kept this in that way?
Message 9 of 10
andrea.amilo
Hi @wrobel094 ,
first of all I am happy that everything seems to work fine.
Changes you made are to write machine angles instead euler angles.
As usual, test it carefully.
Andrea Amilo
Message 10 of 10
Don.Cyr
@wrobel094  have you tested this on your machine with success? Looking to do the similar post mods for our VC-500.
Thank you.
Please click "Accept Solution" if I helped with your question or issue.
