Manual Parameter NC - Comment
bflug
bflug
I am using manual NC for alot of custom functions. Is there any way to access the name that I rename the operation to as a paramater so I can insert it as a comment.
For a standard operation the funtion that does this is:
if (hasParameter("operation-comment")) {
var comment = getParameter("operation-comment");
if (comment) {
writeComment(comment);
I have tried variations like below but they dont seem to work:
if (hasParameter("parameter-comment")) {
var comment = getParameter("parameter-comment");
I'm hoping there is a more elegant solution that putting it in my value as a comment
Laurens-3DTechDraw
Use the dump post processor to find out how the parameter is called for the operations name.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
bflug
It appears the only information passed to the post is the value field and the type of parameter. If anyone stumbles upon this someday and wants a solution I would recommend something like the following
EXAMPLE: manual NC subprogram call value field : BAR FEED CYCLE,OBAR PCR=1 SPOS=0.015
function onSubProgram (value)
writeln("");
onOperationNumber(); (MY CUSTOM NAT COUNTER)
commaIndex = value.indexOf(",");
var subComment = value.substring(0,commaIndex);
var call = value.substring(commaIndex + 1);
writeComment(subComment);
writeln("CALL " + String(call));
writeln("M1");
 will produce ---->
NAT03 (BAR FEED CYCLE)
CALL OBAR PCR=1 SPOS=0.015
M1
