Machining Time, Document Name, Stock Information in NC program
boopathi.sivakumar
Autodesk Autodesk
Message 1 of 13
boopathi.sivakumar
Hi
Since I have seen some common requests on how to add machning time, document name, stock information, user name and nc generated time in the NC programs, So I have came up with this thread and a common places which answers this question.
var infoSettings = {
  toolChangeTime : 15,         // Default tool change time in seconds.
  rapidFeedRate  : 10000,      // Default Machine rapid feedrate in mm/min.
  durationFormat : "HH:MM:SS", // Supported Formats are "HH:MM:SS", "MM:SS" and "SS".
  dateFormat     : "LOCAL_DATE_TIME", // Supported Formats are "GMT", "LOCAL", "LOCAL_DATE_TIME"
  formatSeperator: ": ",       // Use this to seperate words.
  stockMode      : "MILLING",  // Outputs the stock information supported formats are "MILLING", "TURNING" and "CUTTING"
  headerInfo     : {           // writes the header information by calling writeHeaderInfos() function, following are the supported information. set false to not output the Information.
    documentName   : true,
    programmerName : true,
    programmerEmail: false,
    ncGeneratedTime: true,
    stockInfo      : true,
    machiningTime  : true
function writeHeaderInfo() {
  var headerInfo = infoSettings.headerInfo;
  if (headerInfo.documentName) {
    writeComment("Document Name     " + sep + getDocumentName());
  if (headerInfo.programmerName) {
    writeComment("Programmer Name   " + sep + getUserName());
  if (headerInfo.programmerEmail) {
    writeComment("Programmer Email  " + sep + getUserEmail());
  if (headerInfo.ncGeneratedTime) {
    writeComment("Generated At      " + sep + getNCGeneratedTime());
  if (headerInfo.stockInfo) {
    writeComment("Stock Information " + sep + getStockInformation());
  if (headerInfo.machiningTime) {
    writeComment("Machning Time     " + sep + getMachiningTime());
function getMachiningTime() {
  var rapidDistance = 0;
  var cycleTime = infoSettings.toolChangeTime;
  var numberOfSections = getNumberOfSections();
  for (var i = 0; i < numberOfSections; ++i) {
    var section = getSection(i);
    cycleTime += section.getCycleTime();
    rapidDistance += (unit == MM ? section.getRapidDistance() : 25.4 * section.getRapidDistance());
    if (i != 0 && isToolChangeNeeded(section, "number")) {
      cycleTime += infoSettings.toolChangeTime;
  if (infoSettings.rapidFeedRate > 0) {
    cycleTime += rapidDistance / infoSettings.rapidFeedRate * 60;
  return (convertToTimeFormat(cycleTime));
function convertToTimeFormat(cycleTime) {
  var format = infoSettings.durationFormat.split(":")[0];
  var hours, minutes, result, seconds;
  if (format == "HH" || format == "MM") {
    hours = Math.floor(cycleTime / 3600);
    cycleTime -= (format == "HH") ? hours * 3600 : 0;
    minutes = Math.floor(cycleTime / 60);
    cycleTime -= minutes * 60;
  seconds = cycleTime.toFixed(1);
  if (format == "HH") {
    result = hours + "Hrs " + minutes + "Min " + seconds + "Sec";
  } else if (format == "MM") {
    result = minutes + "Min " + seconds + "Sec";
  } else {
    result = seconds + "Sec";
  return result;
function getDocumentName() {
  return getGlobalParameter("document-path", "");
function getUserName() {
  return getGlobalParameter("display-name", "");
function getUserEmail() {
  return getGlobalParameter("user-email", "");
function getNCGeneratedTime() {
  var date = new Date(getGlobalParameter("generated-at", ""));
  if (infoSettings.dateFormat == "GMT") {
    return date.toUTCString();
  } else if (infoSettings.dateFormat == "LOCAL_DATE_TIME") {
    return (date.toLocaleDateString() + "-" + date.toLocaleTimeString());
  } else {
    return date.toLocaleString();
function getStockInformation() {
  var format = createFormat({decimals:(unit == MM ? 2 : 3)});
  var workpiece = getWorkpiece();
  var delta = Vector.diff(workpiece.upper, workpiece.lower);
  var unit_ = unit == MM ? "MM" : "IN";
  var len = format.format(delta.x) + unit_;
  var wid = format.format(delta.y) + unit_;
  var height = format.format(delta.z) + unit_;
  if (infoSettings.stockMode == "TURNING") {
    var dia = format.format(Math.max(delta.x, delta.y)) + unit_;
    return ("Diameter=" + dia + " Length=" + height);
  } else {
    return ("Length=" + len + " Width=" + wid + (infoSettings.stockMode == "MILLING" ? " Height=" : " Thickness=") + height);
var sep = infoSettings.formatSeperator;
if (typeof settings != "undefined" && settings.comments.permittedCommentChars) {
  settings.comments.permittedCommentChars += infoSettings.formatSeperator; // add addtional comment chars
if (typeof permittedCommentChars != "undefined") {
All you can do is copy the above section of code and paste in at the end of your post processor file (.cps)
and call the writeHeaderInfos(); function wherever it is needed
Example on the fanuc post
I have added in the onOpen section
This should output the corresponding heder info in the top of the nc program!
also in the copied section of code the you can use infoSetting object variables to granually control how this needed to be outputed
    stockInfo      : true,
For example you can control the duration of tool Change time so that you get more accurate machining time,
and maximum rapid feedrate of the machine. and in the duration format you can control how do you want to output the machining time for instance.
here is the short video of how you can make edits to the posts to get this done
Feel free to post in the thread if you feel any other options are missing
Boopathi Sivakumar
Principal Technology Consultant
Replies (12)
Message 2 of 13
ktorokU233T
All good stuff@boopathi.sivakumar
Are there any plans to update the post processor engine to be able to pull the actual Fusion 360 user name instead of the Windows user name? Currently the example above will always return the Windows Login user name, not the actual Fusion Login user name. In an environment where there are shared computers on the shop floor, this would be really helpful.
Message 3 of 13
boopathi.sivakumar
Hi @ktorokU233T
Thanks for the feedback I will make a ticket
Boopathi Sivakumar
Message 4 of 13
j_zander
Hi! Is it also possible to post the machining time for every tool? I need that for our robot cells toolmanagementsystem. I need something like this:
Message 5 of 13
mlindleyHW8VL
Community Visitor
Community Visitor
Excellent work. Thank you
Message 6 of 13
jrmitchellj
I am working on a MacBook Pro M4 computer, with OS26.
Is there a Mac centric version of the Post Processor Training Guide?
Message 7 of 13
boopathi.sivakumar
Hi @jrmitchellj
The fusion post processor utility is same for mac as well so pretty much everything is same! apart from couple of things
one is the post executable path for mac will be different You can refer this Thread
if you making a custom .cnc file you have to manually import the cnc file. for windows we do automatically import the custom cnc files but for mac you have to right click on the folder and import cnc file https://cam.autodesk.com/posts/posts/guides/Post%20Processor%20Training%20Guide.pdf#page=54
Boopathi Sivakumar
Message 8 of 13
jrmitchellj
Thank you for the links.  That helped!
It is working now, but the username is not correct. (see attached photos)
You can see line 13 the username is ROOT)  instead of my login.
I also included a snapshot of the code that generates the username.
Thank you for your help!
Ray
Message 9 of 13
boopathi.sivakumar
Hi @jrmitchellj
Currently the user name is your pc host name not the fusion user id. this is something we will be addressing shortly in the coming release of fusion
Boopathi Sivakumar
Message 10 of 13
jrmitchellj
I expected it to be my login on my computer, and I am not logged in as ROOT!
I look forward to the fix.
A more permanent solution would be to add it to the post processor, where they could be enabled/disabled with check marks in the format section.  (see attached screenshot)  jsut below the "Write tools" checkmark.
Message 11 of 13
boopathi.sivakumar
Hello everyone!
With the latest update with Fusion Jan release in addition to existing parameter now the full name of the logged in user has been exposed. also we have also exposed the user logged in email and the unique Autodesk Id has been exposed to use it in the post processing.
To get the Full User name one can get using the following code sinppet
 2 . To get user email
3. To get the unique Autodesk user id.
getGlobalParameter("user-id", "")
I have also updated the above code snippet. Hope it helps for user who has looking for it.
Boopathi Sivakumar
Message 12 of 13
jrmitchellj
Does that mean you updated the code in the first entry in this chain?
Message 13 of 13
ktorokU233T
Thanks for the update @boopathi.sivakumar
Worked like a charm.
