Hi ,
I'm try to using 5 axes in Mach3 but the post processor is for 3 axes only,
is there any way to modify the post processor?
Any help greatly appreciated!
Solved by skidsolo. Go to Solution.
Hi, i know this is an old post, but i just started working with 5-axis machine for my master´s degree and the machine using is also the HY6040 exactly like the one you posted with a small difference, the A and B axis on my machine are the opposite of yours (A axis rotates around Z and B axis rotates around X in my case.
So my question is, can i change these axis on mach3mill or do i have to do it on the post-processor, because, and to be honest, i know nothing when it comes to programming post-processors, my work in entirely dedicated to toolpath generation.
Again i know this is and old post, but if you could help i would be very thankful.
Im working with Fusion360, and i see a lot of people on the internet changing/adapting the default post-processors to their needs, unfortunately i really know nothing about this area.
However i downloaded the post processor you posted and what happens is that, instead of rotating my B axis 90 degrees, it is the A axis that rotates and vice-versa. So if i can change this, the post processor would be great for my work. Is there any way you could explained me how to do it?
BTW thank you for replying 🙂
To my knowledge, a machine with a trunnion and a rotary axis about the Z is an XYZAC machine. "A" rotates along the X axis, "B" rotates about the Y axis and "C" rotates about the Z axis. Then you have the table/table, head/table, and head/head varieties within those.
Same machin and same problem for me.
I use fusion and mach3 5 axis, and i can't use five axis there are big offset after rotation of the trunion.
i think we have to work with an other software, because many people have the same machin and the same problem and autodesk don't want to find a solution...😭
Hi
I use Mach3 with Fusion for 5 axis.
I do not encounter this problem by ....
Setting the setup machine origin to the intersection point of the A and B axes; and the workpiece origin to the centre point of the B axis face. This naturally leads to an offset (difference of the two origins)of either a minus Y value or a minus Z value, dependant upon the whether the B axis face of the trunnion is point forward or upward when A is 0. Fusion and the post processor then takes this into account and will maintain a fixed point as the A axis rotates etc
Maybe you are already doing this. So attached is the Mach 3 post processor I use for my trunnion setup
In this file you will find 2 lines ...
// 'A' OFFSET removed for the A Axis because there isn't one
var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-110.0001,20.000], preference:0});
// 'B' OFFSET on my set up is y-16 with A set to 0 degrees ie B axis Face plate is facing forward
var bAxis = createAxis({coordinate:1, table:true, axis:[0, -1, 0],offset:[0,-16,0],range:[-9999,9999], preference:0});
You will need to amend the offsets and the angular limits for your trunnion setup
Hope this helps and and pleased let me know how you get on and if you need further help
Good luck Richard
Thank you!
Thank you so much for sharing.
you can help me? i want to setup 1 post 5 axix for my pc configuration, thank you, looking forward to getting help.
