- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
After six months of going through online information youtube and the post processor manual, I believe I got the stage where my understanding is past newbie editing level.
1st question - Am having some problems in finding out if the fusion post for the linuxcnc post processor for arcs is in incremental or absolute?
2nd question - Am using the linuxcnc post that I have edited so far for my flashcut controller for a lathe that was converted from manual to cnc, when creating a facing operation all the gcode from the post I created comes out perfectly fine either the generic fanuc turn post or the linuxcnc post , the problem am facing is arc related moves, and I believe I have narrowed it down to that problem.
I have tried using the fanuc turning post similar setup in the post processor that I edited for linuxcnc and the same error occurs when trying to profile.
Error reads "The vector to the center defines an invalid arc. the arc cannot be drawn from the beginning point to the ending point with the center as specified."
Machine zero / program zero all checks out ok, I have disabled the G54 writeblock from the post since it is defined in the controller itself.
Attached my edited linuxcnc post, if it would be easier to work with the fanuc post I can edited similarly to the linuxcnc to match my requirement.
I also checked out the following thread:
Which is fanuc related and not linuxcnc would it be a similar amendment ?
Also when posting in radius mode everything checks out. I would rather use the IJK for purpose of accuracy.
Any insight or guidance would be appreciated.
Using Notepad++ / java syntax highlighting and and alot of coffeeeeeeee 🙂
