Recently I have been using "Use Upgraded Post engine" and have customized a post that works. The post is the Heidenhain Inspection post. At least it worked for a while. Today I went to go post something that is using operation scoped properties to customize the outputted code that I made and it is not posting the correct code anymore. It just completely ignores the whole toolpath.
Also when I use Machine Simulation to simulate the toolpath, It shows the machine not orientated properly and colliding.
I think now my only option is to re-do my post with the older post-engine since I can't use this post with the older post-engine. I am very un-happy right now. I pretty much cant make programs now until I re-do the post.
Solved by rusty.bird. Go to Solution.
Can you pls share your post + a sample part? I´d like to take a look into it. Thanks
I found the problem. It had nothing to do with the post. It was another operation scoped property I had on the procedure that was enabled when it shouldn't of been selected (user selected).
I think I need to do a little bit more troubleshooting before posting on the forum. Anyways crisis averted :).
That was easy then 🙂 Glad it was not the post engine causing problems.
