Issues with 4th axis toolpath generation(possible calculation error)
I am in the process of getting the 4:th axis on my machine working.(a HMC with rotary table centered at the y axis origin).
But I am noticing some very strange behavior when posting code which almost seems like a calculation error of some sort.
if machining a line on a cylinder between B0 and B180 Y0 to (straight line with no lead-ins or tool comp disabled) on a cylinder of diameter 40mm the output I get is over 1000 lines long when the actual output of such a operation should be as simple as:(this is disregarding federate (which my control handles by feeding it the average radius of a move on a cylindrical surface with B5=radius
G0 X0 Y0
G0 Z40 B0
G1 Z20 F150
G1 Y20 B180 B5=20 F150
... retract and things here....
Not 1k lines for a single open contour with a constant slope.
I have seen others with similar problems and it seems like regardless of post modification(even the dumper post agrees to the output) normally I would simply merge the segments with the same slope in the pp but I would prefer getting it properly fixed(it severely limits 4.th axis use to indexing for a lot of people with slightly older controls)
(I notice others are having the same issue).
I can post part file and post processor but the behavior is simple enough to observe with the dumper.
/Anders
