- Mute
- Permalink
- Report
This may look like a strange question, so I will try to explain as best as I can.
On a Roeders machine, probing is done with Roeders commands, where a "target" is defined, rather than with usual G-Code coordinate instructions. It does work well, the only problem is that probing is never simulated, it goes directly to the first milling toolpath.
It would be much nicer if everything could be simulated, probing included. Would this be possible, or I am asking too much?
Bernard Grosperrin, Retired, Maker, and Autodesk Certified Instructor
Blog : Le Bear CNC | Forum : Le Bear CNC Forum | Addin : Airfoil Sketch from file
