Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Is there a post processor for smoothieboard?
kt
Message 1 of 8
kt
Is there a post processor for the smoothieboard?
I have one of those lying around.
Replies (7)
Message 2 of 8
scottmoyse
Maybe try the grbl, tiny g or Linux cnc posts as starting points?
Scott Moyse
Did your question get successfully answered? Please accept the post as a Solution to help others find it.
CAM Consultant and owner at Nominal Systems. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 3 of 8
kt
Thanks i will see.
Its strange autodesk doesnt have one?
Message 4 of 8
Laurens-3DTechDraw
Kent Thoresen wrote:
Thanks i will see.
Why would it be weird that Autodesk doesn't have a post for a very specialist hobbyist control?
But maybe have a look here: http://cam.autodesk.com/posts/?p=smoothie
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 5 of 8
kt
They have a standard version for tiny-g i think smoothie is more common than that? i would assume they would have post prosessors for the most populare driver boards.
Message 6 of 8
Laurens-3DTechDraw
They have posts for nearly all popular serious machine controllers.
But have you had a look at the post I linked to?
Laurens Wijnschenk
3DTechDraw
Message 7 of 8
Here is the one I'm using with HSMXpress.
It's a modified GRBL post, rapids move Z prior to XY to avoid dragging the tool through the work piece. Set rapid feedrate in "highFeedrate".
Message 8 of 8
Thanks Laurens.
Simple search found this post, your post directed me straight to the smoothie PP.
Kudos!
