HSM Post Processor Forum
Is there a Fusion 360 post processor available for an Anilam 3200 MK conversational 2-axis controller?
4 REPLIES 4
781 Views, 4 Replies
The Anilam conversational post processor in the Fusion 360 library is for a 3-axis machine and creates lots of z related commands that cause problems trying to run the code on my machine (Bridgeport mill with x and y servos). Any help would be appreciated, kind of a newbie to using CAM software, learning as I go.
Labels (1)
4 REPLIES 4
billcainautodesk
Hello cekalskinator
That post has a variable in it called "gotZAxis". You can try setting this to false and it should remove the Z axis output.
Bill Cain
Sr. Technical Consultant
in reply to: billcainautodesk
Thank you for the quick reply Bill! I tried that and get the following errors shown below. Fyi, I am post processing Setup1 T1 Face Top in the sample part used in the Fusion 360 Creating Toolpaths and Programs video.
Error: Not XY-plane arcs are not supported by the CNC.
Error at line: 810
Error in operation: 'Face Top'
Failed while processing onCircular() for record 346.
Error: Failed to invoke function 'onCircular'.
Error: Failed to invoke 'onCircular' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, September 82021 3:45:17 PM
Post processing failed.
billcainautodesk
Hello cekalskinator
It's checking for Arcs that are not in the XY plane. You probably have some vertical arcs set in your lead in/out. Look for any Vertical Arcs and remove them and you should be good.
Bill Cain
Thank you Bill for the fix. I set the all vertical lead-in radius to zero and it solved the issue.
