@serge.quiblier
I would like to build the filename from the document-path + job-description, to make it unique without having the user having to think about it. I see the sub-programs names being constructed in the post-processor, but not the main program. Would this be possible? (I could use a property to leave the user free to decide)
If NOT possible, is there a way to basically do the same thing to build a default program name inside the post-processing dialog? I have seen that file name is the result of a function/variable "nc_program_name". Is there a variable like "nc_document_path", for example, that I could use instead, as default?
Bernard Grosperrin, Retired, Maker, and Autodesk Certified Instructor
Blog : Le Bear CNC | Forum : Le Bear CNC Forum | Addin : Airfoil Sketch from file
