Inventor CAM post processor error
samuel_defago
samuel_defago
I'm trying to adapt a post processor for my lathe, a DMG CTX 1250 tc (Main spindle + milling head) with Siemens Sinumerik 840D sl.
When I create any live tooling milling operation, the PP takes the maxSpindleSpeed for the main spindle as the live tool spindle speed.
Ex: If I max my main spindle at 5000RPM in the user parameter when post-processing, it will write out "G97 S1=5000 M1=3" for my milling tool. Also, why G97?
Thank you for any help
Sam
AdamKunzo
The problem is that the postprocessor doesn't distinguish between the maximum speed of the main spindle and the live tool — both were limited by a single property, "Max spindle speed" (3000). I've added a new post property, "Max live tool speed".
Set its value on line 92 in the .cps file according to the actual maximum speed of your machine's live tools.
G97 is correct — the live tool always runs in constant spindle speed (RPM) mode. G96 (constant surface speed) is only used for turning operations.
If my response answers your question, please use Accept Solution button.
samuel_defago
Thank you very much!
Sam
