HSMWorks/RS274D - Oscillation on GCode command on interpolated 5 axis motion.
xavier.soltner
xavier.soltner
Hi guys,
I'm trying to generate GCode for a 5 axis machine  - XYZBC, table-table.
Whether I generate  GCode with TCP support or no TCP support, I get :
  • Big weird oscillation on joint axis - around 0.4mm amplitude on X, Y, and Z joint.
  • Small erratic oscillation, like on Y and B axis of around 0.05mm/0.01deg.
You can see below the raw GCode G01 position for one circle projected on a dome (Full path seen below) :
My setup :
  • Solidworks Premium v2021 SP5.1
  • Plugin HSMWorks v2024 R0.44173 / Post-Processeur v4.5940.0
  • RS-274D Sample Multi-axis Post Processor / révision 44023 / Slightly modify to add specific retract position because of the layout of our machine.
  • Milling of a simple dome while keeping tool normal to the surface :
What I've tried :
  • Playing with different function : isoparametric curve / Multi-axis contour following an esquisse path.
  • Playing with function parameter, on the 4th tab : "Tolerance" / "Maximum Segment Length" / "Maximum Tool Axis Sweep"
Result :
I keep having oscillation or erratic motion on the joint, whatever the parameter cited is set to.
I feel like the FAO/Post-Pro/Kernel is not able to calculate the proper approximated path.
My Question in priority order :
  1. How can I mitigate/cancel this effect ?
  2. Why is it doing this ?
Thanks in advance for any help !
Replies (0)
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
