HSM & CNC CharlyRobot 4U
Thierry_Cnrs
Message 1 of 19
Thierry_Cnrs
Does anyone of you use HSM with a small cnc "CharlyRobot 4U"? In this case, which post processor do you use?
Many thanks
Thierry
Replies (18)
Message 2 of 19
bob.schultz
Hello Thierry,
The CharlyRobot 4U machine seems to use standard ISO programming.  You should try the generic rs274.cps post processor.
Bob Schultz
Sr. Post Processor Developer
Message 3 of 19
Thierry_Cnrs
Thanks for your answer Bob,
I had already try with this post proc, but threre are a lot of errors when I generated the G code file.
I had also try Generic Tiny G and Flexicam and it's almost similar.
I will try to modify one of these but for the moment I don't know how to do it.
Message 4 of 19
bob.schultz
Hello Thierry,
Does the control error out on a specific block?  You should be able to either remove or comment out the blocks that the control doesn't like so that you can see what blocks are causing the problems.  I would think that the standard movement blocks (G1 X Y Z) should be fine.  Once you find out the blocks that the control does not like you can post those blocks on this thread and I can assist you in learning how to make the modifications to the post for your machine.
Bob Schultz
Message 5 of 19
Thierry_Cnrs
(T1 D=10 CR=0 - ZMIN=-0.5 - fraise a bout plat)
N10 G90 G94
N15 G17
N20 G21
N25 G28 G91 Z0
N30 G90
(Adaptatif 2D2)
N35 M9
N40 T1 M6
N45 S15000 M3
N50 G54
N55 M8
N65 G0 X-20.981 Y-31.463
N70 G43 Z15 H1
N75 Z5
N80 Z1.5
N85 G1 Z0.5 F300
N90 X-20.979 Y-31.456 Z0.379
N95 X-20.974 Y-31.435 Z0.261
N100 X-20.965 Y-31.4 Z0.145
N105 X-20.953 Y-31.352 Z0.035
N110 X-20.937 Y-31.292 Z-0.068
N115 X-20.919 Y-31.22 Z-0.163
N120 X-20.897 Y-31.137 Z-0.249
N125 X-20.874 Y-31.045 Z-0.323
N130 X-20.848 Y-30.945 Z-0.385
N135 X-20.821 Y-30.838 Z-0.435
N140 X-20.792 Y-30.727 Z-0.471
N145 X-20.763 Y-30.611 Z-0.493
N150 X-20.733 Y-30.495 Z-0.5
N155 G3 X-19.95 Y-25.051 I-24.731 J6.335
N160 G1 Y-24.901
N165 X-20.19 Y-23.723
N170 X-20.374 Y-22.535
N175 X-20.514 Y-21.341
N180 X-20.62 Y-20.143
N185 X-20.7 Y-18.944
N190 X-20.761 Y-17.744
N195 X-20.807 Y-16.542
N200 X-20.842 Y-15.341
N205 X-20.869 Y-14.139
N210 X-20.889 Y-12.937
N215 X-20.904 Y-11.735
N220 X-20.915 Y-10.533
N225 X-20.924 Y-9.331
N230 X-20.93 Y-8.129
N235 X-20.935 Y-6.927
N240 X-20.941 Y-4.522
N245 X-20.946 Y-0.916
N250 X-20.949 Y5.094
N255 X-20.95 Y15.312
N260 X-20.841 Y15.903
N265 X-20.344 Y16.998
N270 X-19.535 Y17.887
N275 X-18.562 Y18.592
N280 X-17.493 Y19.143
N285 X-16.37 Y19.571
N290 X-15.214 Y19.9
N295 X-14.038 Y20.152
N300 X-12.852 Y20.345
N305 X-11.659 Y20.491
N310 X-10.462 Y20.603
N315 X-9.262 Y20.687
N320 X-8.062 Y20.752
N325 X-6.861 Y20.8
N330 X-5.659 Y20.837
N335 X-4.458 Y20.864
N340 X-3.256 Y20.885
N345 X-2.054 Y20.901
N350 X-0.852 Y20.913
N355 X0.35 Y20.922
N360 X1.552 Y20.929
N365 X2.755 Y20.934
N370 X5.159 Y20.941
N375 X8.765 Y20.946
N380 X14.776 Y20.949
N385 X15.377
N390 X15.964 Y20.821
N395 X17.048 Y20.302
N400 X17.927 Y19.482
N405 X18.624 Y18.502
N410 X19.168 Y17.43
N415 X19.59 Y16.305
N420 X19.914 Y15.147
N425 X20.163 Y13.971
N430 X20.353 Y12.784
N435 X20.498 Y11.591
N440 X20.608 Y10.394
N445 X20.691 Y9.194
N450 X20.754 Y7.994
N455 X20.802 Y6.793
N460 X20.838 Y5.591
N465 X20.866 Y4.39
N470 X20.886 Y3.188
N475 X20.902 Y1.986
N480 X20.914 Y0.784
N485 X20.923 Y-0.419
N490 X20.929 Y-1.621
N495 X20.934 Y-2.823
N500 X20.941 Y-5.227
N505 X20.946 Y-8.833
N510 X20.949 Y-14.844
N515 Y-15.445
N520 X20.802 Y-16.028
N525 X20.26 Y-17.101
N530 X19.429 Y-17.969
N535 X18.443 Y-18.657
N540 X17.368 Y-19.194
N545 X16.24 Y-19.609
N550 X15.081 Y-19.93
N555 X13.904 Y-20.175
N560 X12.717 Y-20.362
N565 X11.523 Y-20.505
N570 X10.326 Y-20.613
N575 X9.127 Y-20.695
N580 X7.926 Y-20.757
N585 X6.725 Y-20.804
N590 X5.523 Y-20.84
N595 X4.322 Y-20.867
N600 X3.12 Y-20.887
N605 X1.918 Y-20.903
N610 X0.716 Y-20.914
N615 X-0.487 Y-20.923
N620 X-1.689 Y-20.93
N625 X-2.891 Y-20.935
N630 X-5.295 Y-20.941
N635 X-8.901 Y-20.946
N640 X-11.305 Y-20.948
N645 X-12.457 Y-20.603
N650 X-13.422 Y-19.886
N655 X-14.201 Y-18.97
N660 X-14.819 Y-17.94
N665 X-15.306 Y-16.84
N670 X-15.685 Y-15.699
N675 X-15.979 Y-14.534
N680 X-16.206 Y-13.353
N685 X-16.381 Y-12.164
N690 X-16.515 Y-10.969
N695 X-16.618 Y-9.772
N700 X-16.696 Y-8.572
N705 X-16.757 Y-7.372
N710 X-16.803 Y-6.17
N715 X-16.838 Y-4.969
N720 X-16.864 Y-3.767
N725 X-16.885 Y-2.565
N730 X-16.9 Y-1.363
N735 X-16.912 Y-0.161
N740 X-16.921 Y1.041
N745 X-16.928 Y2.243
N750 X-16.933 Y3.445
N755 X-16.94 Y5.849
N760 X-16.944 Y8.254
N765 X-16.946 Y9.456
N770 X-16.933 Y10.658
N775 X-16.532 Y11.791
N780 X-15.852 Y12.783
N785 X-14.986 Y13.616
N790 X-13.998 Y14.301
N795 X-12.932 Y14.857
N800 X-11.816 Y15.303
N805 X-10.668 Y15.659
N810 X-9.499 Y15.94
N815 X-8.318 Y16.162
N820 X-7.128 Y16.337
N825 X-5.934 Y16.473
N830 X-4.737 Y16.58
N835 X-3.538 Y16.663
N840 X-2.337 Y16.728
N845 X-1.136 Y16.778
N850 X0.065 Y16.817
N855 X1.267 Y16.847
N860 X2.469 Y16.871
N865 X3.671 Y16.889
N870 X4.873 Y16.903
N875 X6.075 Y16.914
N880 X7.277 Y16.922
N885 X8.479 Y16.928
N890 X9.681 Y16.933
N895 X10.88 Y16.848
N900 X11.992 Y16.389
N905 X12.953 Y15.668
N910 X13.758 Y14.775
N915 X14.418 Y13.77
N920 X14.951 Y12.693
N925 X15.379 Y11.569
N930 X15.719 Y10.416
N935 X15.988 Y9.245
N940 X16.2 Y8.062
N945 X16.366 Y6.871
N950 X16.497 Y5.676
N955 X16.598 Y4.478
N960 X16.677 Y3.279
N965 X16.739 Y2.078
N970 X16.787 Y0.877
N975 X16.824 Y-0.325
N980 X16.852 Y-1.526
N985 X16.875 Y-2.728
N990 X16.892 Y-3.93
N995 X16.905 Y-5.132
N1000 X16.915 Y-6.334
N1005 X16.923 Y-7.536
N1010 X16.93 Y-8.738
N1015 X16.934 Y-9.941
N1020 X16.763 Y-11.13
N1025 X16.239 Y-12.212
N1030 X15.475 Y-13.14
N1035 X14.554 Y-13.913
N1040 X13.53 Y-14.544
N1045 X12.441 Y-15.053
N1050 X11.31 Y-15.46
N1055 X10.153 Y-15.783
N1060 X8.978 Y-16.038
N1065 X7.793 Y-16.24
N1070 X6.601 Y-16.397
N1075 X5.405 Y-16.521
N1080 X4.207 Y-16.617
N1085 X3.007 Y-16.692
N1090 X1.807 Y-16.75
N1095 X0.605 Y-16.795
N1100 X-0.596 Y-16.831
N1105 X-1.798 Y-16.858
N1110 X-3 Y-16.879
N1115 X-4.202 Y-16.895
N1120 X-5.404 Y-16.908
N1125 X-6.606 Y-16.879
N1130 X-7.738 Y-16.475
N1135 X-8.728 Y-15.793
N1140 X-9.563 Y-14.929
N1145 X-10.252 Y-13.943
N1150 X-10.812 Y-12.88
N1155 X-11.262 Y-11.765
N1160 X-11.622 Y-10.618
N1165 X-11.908 Y-9.451
N1170 X-12.134 Y-8.27
N1175 X-12.313 Y-7.081
N1180 X-12.453 Y-5.887
N1185 X-12.563 Y-4.69
N1190 X-12.649 Y-3.491
N1195 X-12.716 Y-2.291
N1200 X-12.768 Y-1.09
N1205 X-12.809 Y0.112
N1210 X-12.84 Y1.313
N1215 X-12.865 Y2.515
N1220 X-12.884 Y3.717
N1225 X-12.899 Y4.919
N1230 X-12.86 Y6.121
N1235 X-12.493 Y7.265
N1240 X-11.859 Y8.287
N1245 X-11.037 Y9.164
N1250 X-10.086 Y9.899
N1255 X-9.048 Y10.505
N1260 X-7.952 Y10.999
N1265 X-6.818 Y11.399
N1270 X-5.66 Y11.72
N1275 X-4.486 Y11.977
N1280 X-3.301 Y12.182
N1285 X-2.11 Y12.345
N1290 X-0.915 Y12.474
N1295 X0.283 Y12.576
N1300 X1.482 Y12.656
N1305 X2.683 Y12.72
N1310 X3.884 Y12.769
N1315 X5.085 Y12.809
N1320 X6.285 Y12.737
N1325 X7.418 Y12.334
N1330 X8.422 Y11.673
N1335 X9.28 Y10.831
N1340 X9.996 Y9.866
N1345 X10.586 Y8.818
N1350 X11.065 Y7.716
N1355 X11.453 Y6.578
N1360 X11.764 Y5.417
N1365 X12.012 Y4.241
N1370 X12.21 Y3.055
N1375 X12.367 Y1.863
N1380 X12.492 Y0.667
N1385 X12.59 Y-0.531
N1390 X12.668 Y-1.73
N1395 X12.729 Y-2.931
N1400 X12.777 Y-4.132
N1405 X12.814 Y-5.333
N1410 X12.672 Y-6.527
N1415 X12.21 Y-7.637
N1420 X11.506 Y-8.611
N1425 X10.634 Y-9.438
N1430 X9.649 Y-10.127
N1435 X8.588 Y-10.693
N1440 X7.477 Y-11.152
N1445 X6.333 Y-11.522
N1450 X5.168 Y-11.819
N1455 X3.99 Y-12.057
N1460 X2.803 Y-12.246
N1465 X1.61 Y-12.395
N1470 X0.414 Y-12.514
N1475 X-0.785 Y-12.607
N1480 X-1.986 Y-12.635
N1485 X-3.145 Y-12.313
N1490 X-4.183 Y-11.708
N1495 X-5.077 Y-10.904
N1500 X-5.827 Y-9.964
N1505 X-6.445 Y-8.933
N1510 X-6.95 Y-7.842
N1515 X-7.358 Y-6.712
N1520 X-7.687 Y-5.555
N1525 X-7.95 Y-4.383
N1530 X-8.16 Y-3.199
N1535 X-8.327 Y-2.008
N1540 X-8.459 Y-0.814
N1545 X-8.564 Y0.384
N1550 X-8.617 Y1.585
N1555 X-8.352 Y2.757
N1560 X-7.801 Y3.826
N1565 X-7.039 Y4.756
N1570 X-6.132 Y5.544
N1575 X-5.125 Y6.201
N1580 X-4.051 Y6.741
N1585 X-2.933 Y7.181
N1590 X-1.785 Y7.538
N1595 X-0.617 Y7.825
N1600 X0.563 Y8.055
N1605 X1.76 Y8.162
N1610 X2.932 Y7.895
N1615 X3.992 Y7.328
N1620 X4.909 Y6.55
N1625 X5.68 Y5.628
N1630 X6.319 Y4.61
N1635 X6.842 Y3.528
N1640 X7.266 Y2.403
N1645 X7.609 Y1.251
N1650 X7.884 Y0.08
N1655 X8.104 Y-1.101
N1660 X8.045 Y-2.302
N1665 X7.633 Y-3.431
N1670 X6.963 Y-4.429
N1675 X6.112 Y-5.279
N1680 X5.142 Y-5.988
N1685 X4.091 Y-6.572
N1690 X2.955 Y-6.966
N1695 X2.355 Y-6.996
N1700 X1.167 Y-6.81
N1705 X0.103 Y-6.251
N1710 X-0.801 Y-5.459
N1715 X-1.55 Y-4.518
N1720 X-2.16 Y-3.483
N1725 X-2.265 Y-3.201
N1730 X-2.401 Y-2.615
N1735 X-2.399 Y-2.54
N1740 X-2.366 Y-1.94
N1745 X-2.065 Y-0.777
N1750 X-1.904 Y-0.523
N1755 X-1.856 Y-0.465
N1760 G3 X-1.682 Y-0.116 I-0.791 J0.612
N1765 G1 X-1.651 Y0.001 Z-0.493
N1770 X-1.619 Y0.115 Z-0.471
N1775 X-1.589 Y0.227 Z-0.435
N1780 X-1.56 Y0.333 Z-0.385
N1785 X-1.533 Y0.433 Z-0.323
N1790 X-1.508 Y0.524 Z-0.249
N1795 X-1.486 Y0.607 Z-0.163
N1800 X-1.466 Y0.679 Z-0.068
N1805 X-1.45 Y0.739 Z0.035
N1810 X-1.437 Y0.787 Z0.145
N1815 X-1.427 Y0.821 Z0.261
N1820 X-1.422 Y0.842 Z0.379
N1825 X-1.42 Y0.849 Z0.5
N1830 G0 Z15
N1840 M9
N1845 G28 G91 Z0
N1850 G28 X0 Y0
N1855 M30
Message 6 of 19
Thierry_Cnrs
Hi Bob,
Many thanks again  for you help.
In attached files:
     "Surfacage.jpg" you can see a screen shot of that want to do.
    "Surfacage.iso" : the file generated by Inventor HSM with post proc rs274.cps (RS-274D). I have just changed the extension (.cnc) in (.iso) for the Charly Robot sotfware.
    "controler errors 1of2 and 2of2" it's the list of all errors.
    "resultat controler charly Robot" it's the g code generated by "Gpilote" the charly robot software if I load the file with  the list of errors
Message 7 of 19
Thierry_Cnrs
Sorry I have make a mistake when I replied;
Message 8 of 19
bob.schultz
Hello Thierry,
Thanks for supplying the NC code and screen shots of the errors.  It seems that this is a very basic control and does not support a lot of the standard G-codes.  You will be better off using the 'wincnc.cps' post processor for your machine, as it does not output a lot of the codes that your controller is complaining about.  You may find that it still does not like some of the codes.  You can easily comment out the lines in the post that output any codes that your controller does not like.
For example, if it does not like the G22 code output by this post, you can comment out the following lines in the onOpen function.
   //writeBlock(gUnitModal.format(20));
   //writeBlock(gUnitModal.format(22));
Bob Schultz
Message 9 of 19
Thierry_Cnrs
Hi Bob,
Thank you for yours advises. I will try with this "post proc" and I will tell you the result.
Message 10 of 19
Hi Thierry,
I think since more than one year, you have made other tries.
I have also an CR4U, and I would like to know If you are able to use a post proc. compatible with this CNC machine
Brgds
Ilonet
Message 11 of 19
eriklidgren
I posted a postprocessor for my Charlyrobot 4U mill in another thread. Maybe you could try and see if it works for you.
Link to thread:
https://forums.autodesk.com/t5/hsm-post-processor-forum/post-error-with-more-than-one-tool-with-modi...
Message 12 of 19
Thierry_Cnrs
Hello, No sorry, I did not advance on this subject but I'm still
interested and I think I'll do new tests soon. Brgds
Message 13 of 19
Thierry_Cnrs
Hi Eriklidgre,
Thanks for your postproc. I will try it and I will tell you the result.
Brgds
Message 14 of 19
Sounds good.
Thank you for the job, I will try it soon.
Have a good day,
Ilonet
Message 15 of 19
I have tested the post proc, and it works.
Thanks a lot, it solved my issue
Ilonet
Message 16 of 19
eriklidgren
Glad it worked for you, I've used it for quite a while now without issues, but you never know if you have tested all cases.
Message 17 of 19
mario.covarrubias
Community Visitor
Community Visitor
Hello!
I'm using the post processor for the Charly4U, it's really usefull!
Do you have the post processor for the 4th Axis??
please, let me know.
Mario
Message 18 of 19
eriklidgren
Glad you found it useful.
I only have a 3-axis mill. So I didn't add support for a 4th axis.
I don't know what is needed for a 4th axis, maybe you could start a new thread and ask what is needed to implement a 4th axis?
Best regards
Erik
Message 19 of 19
Hello !
I would also be very interested if someone could modify this post processor for the 4th axis of the charly 4u !
