Hole position post
Hole position post
steve
Message 1 of 28
Hole position post
steve
I've having trouble trying to figure out why my HAAS post isn't ordering hole locations in a consistent manner.
I have 4 holes in a row. With the center drill and the tap drill, everyting looks great
G98 G81 X0.25 Y-0.875 Z1.0466 R1.2266 F25.
X2.
X4.
X5.75
I copied the toolpath and changed the tool to a tap. Same hole order,  same option "optimize order" checked but now the tool motion is back and forth
G0 Z1.4266
G98 G84 X0.25 Y-0.875 Z0.6875 R1.3701 F17.8572
G80
G0 Z1.4266
G98 G84 X2. Y-0.875 Z0.6875 R1.3701 F17.8572
G80
G1 X0.25 Z1.4266 F500.
G98 G84 X4. Y-0.875 Z0.6875 R1.3701 F17.8572
G80
G98 G84 X5.75 Y-0.875 Z0.6875 R1.3701 F17.8572
G80
I don't understand why it's repeatedly canceling the cyle and returning to the first hole position for every hole.
Replies (27)
Message 21 of 28
Lonnie.Cady
Yes I typically ignore the multiple cycle calls as long as it is not returnign to the initial hole.
Message 22 of 28
Lonnie.Cady
@steve I see you marked this as solved.  How did you solve the part where it keeps returning to the initial hole?  There is clearly something wrong that is causing it to return to the first hole after drilling other holes.
Message 23 of 28
steve
The root of the problem was selecting holes with instersection surfaces. Supressing the intersecting features and reselected the holes seemed to solve the repositioning errors. I was having trouble exploring other options because something about this model was causing HSM to hang for minutes every time I changed a parameter. I even tried reverting to earlier version of HSM with no luck. I eventually got my part posted, made a copy of the file and started deleting operations (each deletion took 5 min) until the problem resolved itself. Anyway, with that fixed, I deleted and recreated the hole operation and it posted with the clean-optimized hole cycle.
Message 24 of 28
Lonnie.Cady
Just had it happen again.
G187
G0 Z0.3618
G98 G81 X-1.9515 Y-0.294 Z0.1295 R0.3618 F1.8 <------------------------------------------- first hole
G80
G0 Z0.3633
G98 G81 X-1.25 Y-0.294 Z0.175 R0.3633 F1.8
G80
G0 X-1.9515 Z0.3642  <------------------------------------------- return to first hole
G98 G81 X-0.5485 Y-0.294 Z0.1295 R0.3642 F1.8
G80
G0 X-1.9515 Z0.3642<------------------------------------------- return to first hole
G98 G81 X2.1735 Y-0.294 Z0.1295 R0.3642 F1.8
G80
Message 25 of 28
AchimN
Can you please share your part so that i can have a look at it?
Achim.N
Principal Technology Consultant
Message 26 of 28
Lonnie.Cady
sure where to you want it sent?
Message 27 of 28
AchimN
Please send it to [email protected]
Achim.N
Message 28 of 28
AchimN
Lonnie did you already send it? I didn´t receive it.
Achim.N
