Heidenhain, patterns in postprocessor
sebek.p.m
sebek.p.m
the patterns in my postprocessor in fusion 360 do not work for me. With the useSubroutinePatterns and useSubroutineCycles options enabled, I marked the code of interest to me, the code looks like this
990 TOOL CALL 3 Z S1500
991 ;Nawiertak
992 TOOL DEF 15
993 L M140 MB MAX
994 M3
995 L X-22.5 Y-22.5 R0 FMAX
996 L Z+16 R0 FMAX
997 M9
998 M8
999 CYCL DEF 200 DRILLING ~
  Q200=+1 ;SET-UP CLEARANCE ~
  Q201=-0.5 ;DEPTH ~
  Q206=50 ;FEED RATE FOR PLUNGING ~
  Q202=+0.5 ;INFEED DEPTH ~
  Q210=0 ;DWELL AT TOP ~
  Q203=+0 ;SURFACE COORDINATE ~
  Q204=+6 ;2ND SET-UP CLEARANCE ~
  Q211=0 ;DWELL AT BOTTOM
1000 L FMAX M99
1001 L X+17.5 FMAX M99
1002 L Y+27.5 FMAX M99
1003 L X-22.5 FMAX M99
1004 L Z+16 FMAX
1005 M9
1006 L M140 MB MAX
1007 * - Drill1 (2)
1008 M5
1009 M1
1010 TOOL CALL 15 Z S531
1011 ;Wiertlo fi 6
1012 TOOL DEF 21
1013 L M140 MB MAX
1014 M3
1015 L X-22.5 Y-22.5 R0 FMAX
1016 L Z+16 R0 FMAX
1017 M9
1018 M8
1019 CYCL DEF 203 UNIVERSAL DRILLING ~
  Q201=-32.803 ;DEPTH ~
  Q206=32 ;FEED RATE FOR PLUNGING ~
  Q202=+2 ;INFEED DEPTH ~
  Q212=+0 ;DECREMENT ~
  Q213=7 ;BREAKS ~
  Q205=+2 ;MIN. PLUNGING DEPTH ~
  Q211=0 ;DWELL TIME AT DEPTH ~
  Q208=MAX ;RETRACTION FEED RATE ~
  Q256=+0.12 ;DIST. FOR CHIP BRKNG
1020 L FMAX M99
1021 L X+17.5 FMAX M99
1022 L Y+27.5 FMAX M99
1023 L X-22.5 FMAX M99
1024 L Z+16 FMAX
1025 M9
1026 L M140 MB MAX
1028 M5
1029 M1
1082 * - Drill1 (3)
1083 TOOL CALL Z S700
1084 M3
1085 L X-22.5 Y-22.5 R0 FMAX
1086 L Z+16 R0 FMAX
1087 CYCL DEF 200 DRILLING ~
  Q201=-3.2 ;DEPTH ~
  Q206=80 ;FEED RATE FOR PLUNGING ~
  Q202=+3.2 ;INFEED DEPTH ~
1088 L FMAX M99
1089 L X+17.5 FMAX M99
1090 L Y+27.5 FMAX M99
1091 L X-22.5 FMAX M99
1092 L Z+16 FMAX
1093 M9
1094 M5
1095 L M140 MB MAX
1096 M30
1097 END PGM 1005 MM
And I would like it to generate something like that
991 ;Nawiertak
992 TOOL DEF 15
993 L M140 MB MAX
994 M3
996 L Z+16 R0 FMAX
997 M9
998 M8
  Q201=-0.5 ;DEPTH ~
1000 CALL LBL 1
1005 M9
1006 L M140 MB MAX
1007 * - Drill1 (2)
1008 M5
1009 M1
1011 ;Wiertlo fi 6
1012 TOOL DEF 21
1013 L M140 MB MAX
1014 M3
1016 L Z+16 R0 FMAX
1017 M9
1018 M8
  Q213=7 ;BREAKS ~
1020 CALL LBL 1
1025 M9
1026 L M140 MB MAX
1028 M5
1029 M1
1082 * - Drill1 (3)
1084 M3
1086 L Z+16 R0 FMAX
  Q201=-3.2 ;DEPTH ~
1088 CALL LBL 1
1093 M9
1094 M5
1095 L M140 MB MAX
1096 M30
1097 LBL 1
1098 L X-22.5 Y-22.5 FMAX M99
1099 L X+17.5 FMAX M99
1100 L Y+27.5 FMAX M99
1101 L X-22.5 FMAX M99
1102 L Z+16 FMAX
1103 LBL
1104 END PGM 1005 MM
thank you for all the help
AchimN
Please search for this setting into your post:
var minimumCyclePoints = 5; // minimum number of points in cycle operation to consider for subprogram
and set your desired minimum number of points, in your case you have to set it to 1:
var minimumCyclePoints = 1; // minimum number of points in cycle operation to consider for subprogram
Achim.N
Principal Technology Consultant
