HAAS TM-2P Post Processor
lashleyncXSUH5
Observer Observer
lashleyncXSUH5
Observer
Observer
I am new to Fusion and Machining.  That said, I can't find the HAAS TM-2P in the post processor library.  Yes, I have chosen the HAAS NGC, but the default feed rate (650) exceeds my machine (400) along with other parameters being off.  Is there a HAAS TM-2P to upload in the library?  Thanks.
lashleyncXSUH5
Observer
Observer
Phoned a friend with same machine and you just use HAAS NGC and select G0 in post processor settings.
serge.quiblier
Hello @lashleyncXSUH5
you could also have edited the post in order to change the line
highFeedrate = (unit == IN) ? 500 : 5000;
The first value 500 is the high feed rate in inche mode.
The second value 5000 is for the millimeter mode.
Yes i know that it is not a correct conversion.
One inche if twenty five point four millimeters.
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
