HSM Post Processor Forum
Haas NG Post acts differently if copied into Linked or Local
1 REPLY 1
gjblock01
218 Views, 1 Reply
I am generating output for Haas TM1P with TRT160.
If I execute the Post out of Linked folder, it works.
If I execute the Post out of Local folder, I get a "Direction not supported" error.
The files in each of these locations are identical.
One other comment: when I first copy the Fusion 360 Library Post into Local, the green "User modified" icon shows on the screen, even though it has not been modified.
1 REPLY 1
Hello, @gjblock01 . Are you using the same post properties for both posts? Post properties are bound to post location, and not copied over.
Are you using machine with the post?
Viacheslav Shapilov
Developer Technical Services
Autodesk Developer Network
