HSM Post Processor Forum
Haas Nextgen post not rotating just Caxis (UMC1000/Fusion360)
5 REPLIES 5
822 Views, 5 Replies
Bit of an odd post issue. The part currently in the machine just needs to rotate along z, using the c axis on the machine. This is just to avoid resetting the part in the machine, as I've run out of Y axis travel.
I've sketched a line to set x along to move the part enough,and I'm using a simple adaptive rough and then contour toolpath with tool orientation set. When posting there is no C axis rotation, nor is there an error (neither machine side or software side) letting me know this rotation isn't happening - which could very easily scrap the part!
I don't think I need to post/share the project or post, as I do believe this will happen regardless doing these moves using the current Haas nextgen post from the library.
5 REPLIES 5
boopathi.sivakumar
Hi @Anonymous
By default the post processor will adjust the coordinates in x,y if there is any orentation along Z axis,
the post needs to be bit modified to handle the orentation along z, to modify the post change as mentioned below
find for the function getWorkPlaneMachineABC
instead of var abc = machineConfguration.getABC(W); change the logic as mentioned below
function getWorkPlaneMachineABC(workPlane, _setWorkPlane) {
  var W = workPlane; // map to global frame
// add the logic from here
  if (currentSection.isZOriented()) {
    var abc = new Vector(0, 0, -Math.atan2(currentSection.workPlane.right.y, currentSection.workPlane.right.x));
  } else {
    var abc = machineConfiguration.getABC(W);
// to here
  if (closestABC && !currentSection.isZOriented()) {    //<< change the logic like this
    if (currentMachineABC) {
      abc = remapToABC(abc, currentMachineABC);
    } else {
save the post and test it carefully, do the air pass test it before you go for real cutting
and let me know the feedback
Boopathi Sivakumar
Senior Technology Consultant
in reply to: boopathi.sivakumar
Below is the code I used. Seems to translate C backwards, as the posted program turn clockwise when I've got it set to be skewed CCW.
I'm not sure I edited correct, JS surly isn't my day job!
  } else {
  //var abc = machineConfiguration.getABC(W);
    } else {
      abc = machineConfiguration.getPreferredABC(abc);
  } else {
  try {
    abc = machineConfiguration.remapABC(abc);
    if (_setWorkPlane) {
      currentMachineABC = abc;
boopathi.sivakumar
@Anonymous
you did the correct modification could you try removing the - sign before the Math
 var abc = new Vector(0, 0, -Math.atan2(currentSection.workPlane.right.y....
 it should look something like this
var abc = new Vector(0, 0, Math.atan2(currentSection.workPlane.right.y, currentSection.workPlane.right.x));
carefully test the codes in machine and let me know the feedback
Boopathi Sivakumar
Worked perfect! back to making chips!
Thanks!
Hi Boopathi,
I'm facing the same issue with the Syntec/Fanuc controller, can you please advise how to make the same change? Post section as folllow:
 } else {
      if (useMultiAxisFeatures) {
       abc = getWorkPlaneMachineABC(_section.workPlane, false, true);
        var newWorkPlane = machineConfiguration.getOrientation(abc);
        euler = newWorkPlane.getEuler2(EULER_ZXZ_R);
        abc = new Vector(euler.x, euler.y, euler.z);
      } else {
        abc = getWorkPlaneMachineABC(_section.workPlane, _setWorkPlane, true);
        setWorkPlane(abc);
I understand the theory of ignoring the rotate around Z tool orientation, however given the user had to intentionally setup the tool orientation it seems a little odd to ignore this as a default? As with the creater of this thread, we are also intentionally rotating about C to gain access to areas of the part which are outside of the maching window.
Ray
