HSM Post Processor Forum
Haas A-axis Post - Making Retract Position Variable
10 REPLIES 10
Message 1 of 11
1510 Views, 10 Replies
Quick question for the masses:
I am using the default Haas with A axis post provided with HSM.
Everytime a rotary move is commanded, the post sends the machine to home in the Z axis.
Is there a way to make this retract distance a user-defined variable?
Along the same lines, the post also retracts to Z home when switching work offsets.
I know lonnie has a version of the haas post that only retracts to the clearance plane when changing offsets.
This may work, but I possibly would like a "happy medium" retract distance.  Somewhere between home and and the part clearance plane.
Any suggestions on post edits here?
Steve
10 REPLIES 10
Message 2 of 11
Laurens-3DTechDraw
Not at a pc now. But you would want the retractions for which fullretract is true to have a property in the post that you can set at the post process screen.
Assuming the toolchange doesnt do a full retract. If that uses full retract as well you would need a little more complicated edit
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 3 of 11
Greg_Haisley
Clearance plane (clearance radius in this case) would be nice a solution. Also when moving from job to job within the same program, this scenario currently goes back to Z home also. It is a safe practice, but costs machine time.
Message 4 of 11
Doing some post editing today, so I figured I would bump this to the top.
Any ideas on making the retract between WCS changes and on rotary moves a variable height?
Steve
Message 5 of 11
Greg_Haisley
I thought that some of the posts have a retract to clearance plane option in the properties page. Would be nice to see this for indexes and/or work offset changes for all posts.
Message 6 of 11
AchimN
Steve have a look in your inbox, there should be a working solution for you 😉
Achim.N
Principal Technology Consultant
Message 7 of 11
soldanr
in reply to: AchimN
Would love to get a copy of that post!?
I find the G53 G0 Z0 annoying as well. 🙂
Message 8 of 11
AchimN
in reply to: soldanr
You can customize the Z value in the G53 line to your desired value.
Using G53 is the safest way to handle retracts.
Achim.N
Message 9 of 11
soldanr
in reply to: AchimN
Thanks. I still want to use the G53 Z0 to go home on the "on close".
During tool changes M5, M9 and G53 G0 Z0 are not required. The machine knows that.
I don't want to have the machine going home for every new work plane plane change. I rather control that myself with the clearance plane.
So I think I found it:
Changed line
if ((insertToolCall && !properties.fastToolChange) || newWorkOffset || newWorkPlane || toolChecked) {
to
if ((insertToolCall && !properties.fastToolChange) || newWorkOffset || toolChecked) {
PS: I am not responsible for any crashes on your machine. Use edit at your own risk. Smiley Indifferent
Hope it helps someone.
Message 10 of 11
sderyck
Has anyone made this change and if so can they send me some sample code from the change
thanks
Message 11 of 11
soldanr
in reply to: sderyck
I made the change. The only difference is that you will not see a G53 between work offset changes. It is a little dangerous. Ha!
