Forcing feedOutput - Okuma LB3000 with OSP-300 control
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm using the generic PP for " OSP-300 control"
https://cam.autodesk.com/hsmposts?p=okuma_lb3000_mill-turn
Two things I need to modify, If you can please help me with.
In the below code (and any other cycles), If the line starts with G cycles, then the line must have all the necessary commands, including Feedrate. But in the generic PP I'm using, if there are 2 or more of the same cycle after each other, then the F only presents in the first one.
G181 X75. C150. Z-42.502 K40. D8.502 F128.(This is already generated and works just fine)
X75. C120. Z-42.502 (as long as the x and z are the same, they should be intoned - so the red ones should be deleted)
X75. C90. Z-42.502
X75. C60. Z-42.502
X75. C30. Z-42.502
X75. C0. Z-42.502
X75. C330. Z-42.502
G180
G0 Z6.
G181 X45.4 C0. Z-45.502 K38.7 D12.802 F128.(Here the Feedrate is missing and needs to be added)
X45.4 C60. Z-45.502 (again, red ones to be removed)
X45.4 C102.22 Z-45.502
X45.4 C180. Z-45.502
G180
G0 Z16.
M12
M146
Also I want to get rid of the red ones
Thanks in advance
