Folder Notes in post?
Hi!
We can add notes to Job, Folder (inside the job) and Operation, but in post we can only get Job and Operation Notes (using 'job-notes' and 'notes' parameters respectively). Is there a way to get folder notes in post?
Laurens-3DTechDraw
Stepa wrote:
Hi!
No.
So I think I see an enhancement request here.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
ArjanDijk
The same goes for "manual-nc" notes. There is no passthrough. This has something to do that manual-nc is not seen as an operation. Its for example not possible to only post a manual nc operation.
I'd like to use notes for easy multiline plain textoutput to the post. This is at the moment not possible with anything else than an operation.
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
Laurens-3DTechDraw
Arjan,
Using the passthrough is only more tricky in the way you need to force a ; between the lines you want.
I mean it doesn't look nice in the box but it works great.
Laurens Wijnschenk
3DTechDraw
René for Legend.
ArjanDijk
Hi Laurens,
Its all kind of a workaround, but if I can make a custom operation with multiple lines, it wil work ok as a template. If its single line its just to much info on one line.
See example, what do you think is more clear to the user 🙂
Laurens-3DTechDraw
I think the one where it's in one line in the passthrough is more clear, because the operation shows what it does.
Where the notes are hidden from the "normal" workflow.
Maybe would be something the guys can take a look at when this Idea gets implemented: http://forums.autodesk.com/t5/ideastation-request-a-feature-or/create-your-own-manual-nc-options/idc...
(In other words vote and possibly add your comments)
Laurens Wijnschenk
3DTechDraw
René for Legend.
ArjanDijk
I voted for you idea Laurens.
