I'm getting the following error when trying to post process a drill tapping operation with Flexicam Post processor :
"Error: Unsupported speed-feed synchronization activation command.
Error in operation: 'Drill2'
Failed while processing onCycle() for record 785."
Any idea about how to solve it ?
Thanks !
Solved by serge.quiblier. Go to Solution.
Hello @duarte.motainl
In it's current state, the post is not supporting any drilling or tapping canned cycles. (i.e. G81-G89 codes)
So, it is attempting to create a long hand output, with G1 moves.
But there is no code, for ensuring synchronization, between the spindle speed and the feedrate.
That's why it can't generate gcode.
If the controller supports canned cycles, the post need to be updated.
If there is a command (M code, or G code) for spindle / feed synchronization just tell us.
But the documentation available, when we wrote the post, did not contains this information.
That's why it has not been implemented.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
