Felder Post Processor, Faces 5 and 6 error.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
I was doing some basic tests on my Felder Profit H350. I did a very simple program that mills a slot on faces 3, 4, 5 and 6 (see picture attached)
The program works perfectly for faces 3 and 4, however on faces 5 and 6 it makes a mess, here is a picture of what the TPA software is interpreting:
I checked the code and for some reason the first two lines and the last one for the operations on face (WF=) 5 and 6 have the X(#1) value inverted.
TPA\ALBATROS\EDICAD\01.00:74:r0w0
$=1001
::SIDE=0;
::UNm DL=368.3 DH=368.3 DS=12
VAR{
}VAR
OPTI{
}OPTI
SIDE#0{
W#89{ ::WTs WF=3 #201=1 #2002=18000 #2005=3000 #203=1 #8015=0 #205=1007 #40=0 #1=214.15 #2=3 #3=15 }W
W#2201{ ::WTl WF=3 #1=214 #2=3 #3=15 #8015=0 #2008=23 }W
W#2201{ ::WTl WF=3 #1=214 #2=3 #3=5 #8015=0 }W
W#2201{ ::WTl WF=3 #1=214.15 #2=3 #3=2.5 #8015=0 #2008=508 }W
W#2201{ ::WTl WF=3 #1=214.15 #2=3 #3=-2 #8015=0 }W
W#2101{ ::WTa #1=154.15 #2=3 #3=-2 #31=-30 #32=-72 #34=1 #8015=0 #2008=3000 }W
W#2201{ ::WTl WF=3 #1=154 #2=3 #3=15 #8015=0 #2008=23 }W
W#89{ ::WTs WF=4 #201=1 #2002=18000 #2005=3000 #203=1 #8015=0 #205=1007 #40=0 #1=214.15 #2=3 #3=15 }W
W#2201{ ::WTl WF=4 #1=214 #2=3 #3=15 #8015=0 #2008=23 }W
W#2201{ ::WTl WF=4 #1=214 #2=3 #3=5 #8015=0 }W
W#2201{ ::WTl WF=4 #1=214.15 #2=3 #3=2.5 #8015=0 #2008=508 }W
W#2201{ ::WTl WF=4 #1=214.15 #2=3 #3=-2 #8015=0 }W
W#2201{ ::WTl WF=4 #1=154 #2=3 #3=15 #8015=0 #2008=23 }W
W#89{ ::WTs WF=5 #201=1 #2002=18000 #2005=3000 #203=1 #8015=0 #205=1007 #40=0 #1=154.15 #2=3 #3=15 }W
W#2201{ ::WTl WF=5 #1=-154 #2=3 #3=15 #8015=0 #2008=23 }W
W#2201{ ::WTl WF=5 #1=-154 #2=3 #3=5 #8015=0 }W
W#2201{ ::WTl WF=5 #1=154.15 #2=3 #3=2.5 #8015=0 #2008=508 }W
W#2201{ ::WTl WF=5 #1=154.15 #2=3 #3=-2 #8015=0 }W
W#2101{ ::WTa #1=214.15 #2=3 #3=-2 #31=30 #32=-72 #34=0 #8015=0 #2008=3000 }W
W#2201{ ::WTl WF=5 #1=-214 #2=3 #3=15 #8015=0 #2008=23 }W
W#89{ ::WTs WF=6 #201=1 #2002=18000 #2005=3000 #203=1 #8015=0 #205=1007 #40=0 #1=154.15 #2=3 #3=15 }W
W#2201{ ::WTl WF=6 #1=-154 #2=3 #3=15 #8015=0 #2008=23 }W
W#2201{ ::WTl WF=6 #1=-154 #2=3 #3=5 #8015=0 }W
W#2201{ ::WTl WF=6 #1=154.15 #2=3 #3=2.5 #8015=0 #2008=508 }W
W#2201{ ::WTl WF=6 #1=154.15 #2=3 #3=-2 #8015=0 }W
W#2201{ ::WTl WF=6 #1=-214 #2=3 #3=15 #8015=0 #2008=23 }W
}SIDE
SIDE#1 {
$=F #1
}SIDE
SIDE#3 {
$=F #3
}SIDE
SIDE#4 {
$=F #4
}SIDE
SIDE#5 {
$=F #5
}SIDE
SIDE#6 {
$=F #6
}SIDEI manually changed the X(#1) value ot those lines to a positive value and the issue was resolved:
I checked the post processor but I can't find the error. The invertX value is set to true on faces 5 and 6 as it should, but apparently it is ignoring it for the first two lines as well as the last one for those operations.
I would really appreciate it if someone could help me edit the PP so I don't have to manually change the values each time I want to use faces 5 and 6.
Thanks!
