Hi Guys,
I am thinking of moving from CAMWORKS to Fusion 360 and i'm having some issues getting my post processor to do what I want. It's mainly that I have no idea how to code. After watching several of the videos on tweaking a post processor, i'm still at a loss. I did manage to change the highspeed code from G05.1 P1 to G05P1000 but i'm stuck on the rest.
I need:
T1 M6 changed to M6 T1 (long story, but I used to have multiple spindles on one of the machines and this is the only way it will work)
I need to add an "A" axis
M11 (spindle brake unclamp)
A axis move
M10 (spindle brake clamp)
I typically use WCS for each A axis move as I have tombstones on the machines that aren't totally square, and don't turn concentrically with the center of the A axis. Is there a way to output 4 axis moves between multiple setups? For instance:
Setup 1- G54 A0.
Setup 2- G55 A0.
Would be willing to even pay to get this resolved.
Doing triple posts of the same problem does not help. you have to wait for a reply or get hold of a reseller
i just thought i may have posted in the wrong place and cannot seem to find a way to delete the forum posts or i would have. thanks for the response
You are now in the correct spot looks like this got moved over here,you were in the correct spot with your first 2 posts.
You just report the post to admin and ask them to move it or remove it, If you ask nicely they usually do
Please sent me a PM, we can help you with your postprocessor.
/Roel
