Fanuc 5-Axis Simultaneous Milling Without TCP (G43.5)
abrownAG8YF
Message 1 of 8
abrownAG8YF
Hello all,
My company has several Fanuc Robodrills with 31i-A5 controllers, but unfortunately none of them have Fanuc's true five-axis (tool center point control) enabled, only 3+2 milling. Using a slightly edited version of the generic five-axis Robodrill post from Autodesk I've been able to do quite a lot, but can anyone suggest how I could edit the post to do true five-axis work without the Fanuc TCP option? I've attached the post I'm currently using.
I've already gotten a quote from them but have a hot five-axis job that I'd like to move forward on. I do realize that without TCP I have to program on the axes rotation origin, but I'm already doing that anyway. Thanks in advance!
Replies (7)
Message 2 of 8
Laurens-3DTechDraw
I'm looking into this and I think the post is set-up wrong.
@AchimN
By default, it now uses G43.5 for multi-axis commands.
And then gives the pre positioning of the A and C axis.
But according to my Fanuc manuals this is not allowed/possible:
@abrownAG8YF
I do have the idea that if you remove the G43.5 and replace it with G43 that it should already work in the current setup.
But be very careful at testing that.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 3 of 8
abrownAG8YF
My company is installing the Fanuc Tool Center Point Control option this week. I will test the five-axis simultaneous post and let you know if the G43.5 works.
Message 4 of 8
AchimN
@Laurens-3DTechDraw thanks, I´ve fixed that problem. Updated posts will show up soon in the library.
Achim.N
Principal Technology Consultant
Message 5 of 8
abrownAG8YF
I've read that tool center point control requires a higher data resolution (IS-E instead of IS-B) for the machine to accurately calculate vectors and positioning. Is output resolution (i.e. .00001" instead of .0001") controlled in the post processor or in HSMWorks?
Message 6 of 8
AchimN
You can control the number of decimals for IJK vectors into the post in this line:
var ijkFormat = createFormat({decimals:6, forceDecimal:true}); // unitless
Achim.N
Message 7 of 8
abrownAG8YF
Thank you. I see it is set to six decimals by default, which is the recommended resolution.
Going back to my original question, I just downloaded and tried to use the latest Fanuc Robodrill post. My machine does not have TCPC (G43.5) installed yet, nor does it have tilted work plane installed (G68/G69). How would I turn this off in the post and force it to use the A, B, or C rotational commands?
Message 8 of 8
Laurens-3DTechDraw
@abrownAG8YF
There is a line in the post that looks like this
var useMultiAxisFeatures = true;
change it to this:
var useMultiAxisFeatures = false;
Laurens Wijnschenk
3DTechDraw
René for Legend.
