export cnc file to vs code post processing error
When i try to post out using export cnc file to vs code get an error
I have the HSM post processer extension installed.
Information: Configuration: Export CNC file to Visual Studio Code
Information: Vendor: Autodesk
Information: Posting intermediate data to 'C:\Users\redward2\AppData\Local\Inventor HSM\nc\mori5 test.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Friday, November 30, 2018 1:54:32 PM
Post processor engine: 4.2.1 42116
Configuration path: C:\Users\redward2\AppData\Roaming\Autodesk\Inventor HSM\Posts\export cnc file to vs code.cps
Include paths: C:\Users\redward2\AppData\Roaming\Autodesk\Inventor HSM\Posts
Configuration modification date: Tuesday, September 11, 2018 12:27:05 PM
Output path: C:\Users\redward2\AppData\Local\Inventor HSM\nc\mori5 test.nc
Checksum of intermediate NC data: b2604b4849e353f4bdfbb9bdcf3a57e9
Checksum of configuration: 9d8c6c4956a23afdcbffce8c1cee0fd9
Vendor url: http://www.autodesk.com
Legal: Copyright (C) 2012-2017 by Autodesk, Inc.
Generated by: Inventor HSM Ultimate 6.3.1.16154
Error: Visual Studio Code not found.
Error at line: 47
Failed while processing onSectionEnd() for record 413.
Error: Failed to invoke function 'onClose'.
Error: Failed to invoke 'onClose' in the post configuration.
Error: Failed to execute configuration.
Stop time: Friday, November 30, 2018 1:54:32 PM
Post processing failed.
AchimN
Are you using the latest version of the addin? If so, please try to download the "CNC exporting post" again since there was an update for that as well recently.
Achim.N
Principal Technology Consultant
Thank you
that fixed the problem
uwe6T7DB
I repeated the installation of the vs code extension as well as the download of "export cnc file to vs code.cps" several times but the cps file has no contents at all (size = 0 kB).
What am I missing ?
Uwe
fy
I have same problem.So I watched source "export cnc file to vs code.cps". I wander  this sentence [ 28:  if (getPlatform() == "WIN32")] .
Is this file support  "win32" only?
Please tell me same advice.
FY
