Adding probing to OSP 300 control.
I have a modified post for OSP 300 Mill control I would like to see if anyone could help out with editing the post for a Renishaw OMP 40 Probe?
TIA
Laurens-3DTechDraw
Best place to start would be to copy the Haas next generation probing cycles over.
Find that here: https://cam.autodesk.com/hsmposts?p=haas_next_generation
Then start adding the logic to keep it from having trouble outputting spindle-speeds and coolant codes and you should be ready to go.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Some one else edited the post for us, its not something I would feel comfortable doing on my own.
Laurens-3DTechDraw
Here on the forum we can help you make the changes, but you will still have to do the testing and checking of the output yourself.
If you want more security I would advise contacting a reseller.
Laurens Wijnschenk
3DTechDraw
