Excel setup sheet post
dames123
dames123
Hello all,
Is there a way to get $program.workOffset to output G54, G55, G56 etc. instead of 1,2,3 in the excel setup sheet post?
Thanks.
andrea.amilo
Hello @dames123 ,
you could try to modify the original 'Setup Sheet Excel' postprocessor as shown below:
adding  + 53  at the end of line 539.
Please test it carefully and let me know. Thanks.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
dames123
Hi @andrea.amilo ,
I tried that and it doesn't seem to work. I'm not sure what $program.workOffset is referencing in the template.
Thanks.
andrea.amilo
Hello @dames123 ,
could you please attach here the postprocessor you are using and a picture of the resulting spreadsheet, showing me the modification you need ?
Andrea Amilo
dames123
Hi @andrea.amilo ,
I would like to see 54,55,56 instead of 1,2,3 on the fixture offset. This is just something the operators are not used to seeing.
Thanks.
andrea.amilo
Hello @dames123 ,
please try to modify the line 192 as highlighted above:
Test it carefully and let me know.
Thanks.
Andrea Amilo
dames123
Brilliant! Thanks @andrea.amilo
