Excel dump file help - simple export
Six1Seven1
Six1Seven1
I have strained my eyes at the setup sheet post and the dump posts available for download and being entirely unfamiliar with the posts API and all the stuff that is being done, I think i would learn fastest if someone could provide a post that is similar to what I need.
Platform i am using is Fusion 360. All i need to do is get the tool number, tool description, toolpath type and cycle time for each operation and list these in columns in excel. I don't need anything more or anything less.
If anyone has any resources or posts they would be willing to provide, I would greatly appreciate the help.
Thank you!
Six1Seven1
**UPDATE:
So i am learning a bit. I guess to achieve this, I might not have to actually edit the post processor,
but just use the existing template and modify it accordingly... which i am finding to be very un-intuitive.
What are the implications of the marriage between the post and the stock template? There is no info on this besides deciphering every line of the code. Deleting a worksheet crashes the post. But somehow deleting the named ranges doesn't. Deleting multiple fields doesn't crash the post, but deleting the screen capture image object does... These
are things only found through trial and error or.... deciphering the code, which is like reading Chinese with one eye and it's blind.
Regards
Six1Seven1
**UPDATE #2
Turns out i was missing the ROW code in my custom template to import operation data. After fooling around a bit,
i've actually got what i wanted...
In case anyone needs a template to just pull the operations and basic info, here is my example:
